I have a question about the TMP006 infrared thermopile sensor. We use this sensor in a mobile application and a low energy consumption is therefore very important for us. A short time period for the measurement is crucial.
the process:
The sensor is supplied with power and gets configured with 0x7000. After the data ready bit is set, the temperature values are read out once and finally the power supply is switched off. This process is repeated every 60 seconds.
the problem:
We have found out that the values of the IIR measurement at the first sampling is incorrect. Until the second sample process the values are correct. Is this circumstance known? In the datasheet I can’t find anything about this. Is there any workaround?
Would be happy about some information’s about this situation.
Thank you!
Thomas
