My customer has been experiencing a problem with the TI LM73 temperature sensor, where it reports incorrect values in the field. So far, they've been unable to reproduce this on their bench. From the symptoms, it sounds like a Power supply ramp-up problem that is documented on Page 19 of the LM73 datasheet. However, the description on Page 19 does not say what ramp-up rate will cause the problem to occur.
As I need a way of getting the LM73 into this state in order to test out the workaround, would your team be able to share the proper slew rate needed to make the problem manifest?
This is affecting several product in the field so please help asap.
