Hello Gerry,
First of all, thanks for that detailed explanation it really helps zero down your issue quickly. Based on your explanation, your physical connections to the TMP006 are correct.
Now, when you say " Initial attempts to talk to the chip after system power up or reset always fail, apparently due to missing ACK from TMP006" - How long after power up or rest do you initiate serial wire START condition?
When you are telling me that your MFR, DEV ID are correct - Soldering Issues and Connection Issues are off our list. Now, whereas at the same time when you are telling me that VO and Tamb are zero - This happens when the internal sensor is damaged.
This happened to me during handling(while soldering) or making a physical contact with the part (top side) on various occasions. Replacing this part with a new one should fix it. If it still doesn't - Please send me SCL, SDA wave forms along with Power-up condition and I will investigate further into this.
Hope you this helps!
Abhi Muppiri
Applications Engineer
MHR- Sensing Products
Texas Instruments
Search for answers, Ask a question, click Verify when complete, In the process, Help others, Learn more...
Hello Gerry,
Glad to know that we were able to solve the issue. Good luck!
Abhi
