About Temperature Data Format of TMP006.
Guru 19645 points
Other Parts Discussed in Thread: TMP006
About datasheet table 7."Temperature Data Format" of TMP006, To "DIGITAL OUTPUT (BINARY)", the value of "SHIFTED HEX" is carrying out a 2-bit shift to the right, when "TEMPERATURE(℃)" is positive, but when negative, it has not shifted.
Such data will not be right?
Moreover, is the above-mentioned explanatory note in somewhere?
Thank you for your consideration.
  • Hi Satoshi,
    Thank you for bringing this error in our data sheet to our attention...you are correct.  we have made the necessary changes and are in the process of rereleasingvthe corrected data sheet to the web.  With the US Holidays coming it may take into early next year to have this transition completed.  TI appreciates you contacing us on this issue and apologize for any inconvenience this may have caused.
  • Dear Edward Mullins-san
    Thank you for the early reply.
    Carrying out introduction Update next year, I understood.
    A point in question becomes clear and appreciates.
    Satoshi
