Hey everyone,
I want to measure the angle between to robotic arm, at a joint that is designed around a Harmonic Drive gearbox.
My first approach was using a custom made PCB designed in SolidWorks, following the Inductive Sensing broshures and the LDC1000 datasheet. It looks like this:
What I get is a unlinear behaviour of the output data (which is actually to be expected).
I don't see a good way to design a encoder PCB that is similar in shape to the one from the datasheet. Does anyone have hints on this topic? Also, which might be the best material to use? I tried usual FR4 PCB material and Aluminum sheet.
Thanks for the help!
Regards from Germany.
