Hall Sensor DVR5013 ?
Other Parts Discussed in Thread: DRV5013
I want to use the hall effect sensor DRV5013 for making a metal detector which detects ferrous and non-ferrous metallic objects by sensing the variations in geomagnetic field. I am not sure if this sensor is suitable for this purpose as I have just conceived this idea myself. Reading the data sheet does not answer this to me as well. Can anyone give remarks on this ?
Also, I could not find the evaluation or development boards that could be purchased to evaluate this sensor and do basic prototyping. Any ideas guys ?
Kind Regards
    This forum is for questions related to TI's analog solutions for automotive systems.  I will move your question to the appropriate forum.
  • Hi Umair,
    One thing you might want to consider is that ferromagnetic elements are usually not magnetized naturally.  Iron, cobalt, and nickel in the ground won't produce much of a magnetic field unless they are magnetized with a strong magnetic field.
    A field of 4mT is needed to guaranteed turn-on the DRV5013AD.
    We don't currently offer an evaluation board for this 3-pin device.  However you can get free samples of the through-hole version (TO-92) and attach to the leads directly or use with a breadboard.
    RE
