In our application we use LDC1000 to measure rather small inductance (nH).
We have connected LDC1000 to MCU and are able to communicate over SPI.
We can read/write values and also read of defaults returns values that defined in spec.
We are able to measure inductor that supplied with LDC1000 EVB.
But when we connect our inductor we get status register 0xF0, that means "oscillator overloaded and stopped" and read all zeroes from frequency and proximity data registers.
We have tried to reduce RPmin to the minimum, but this doesn't helps.
The interesting part of this brainteaser, that if we connect our inductor to PC (EVM) we are able to measure inductance, e.g. we can read values and status is OK.
When we check frequency of osculation with both inductors we see the same picture on EVM and in our setup.
You can see below two snapshots, one form inductor supplied with EVM while another one from our inductor.
EVM inductor:
Our inductor:
And again, we see the same pictures on EVM, but in our setup we receive overload error, while EVM works without problem.
What we are doing wrong ?
John.
