I've setup the TDC1000-TDC7200 EVM so that it can actually measure fluid level by rigging a submersible pump inside a container to have the water level rise and fall. I was expecting the TDC7200 to calculate and provide results for each variation. Except I found out that I have to mechanically bond the sensor to the container and not just stick it on like many people did.
Now my other problem is when I turn off the pump so that water level can fall, the USB connection from the TDC1000 EVM is cut. I tried using a totally separate source but the same thing happens. Why do you think this happens?
Norman
