Other Parts Discussed in Thread: TMP112
Hello community,
the datasheet for the temperature sensor TMP112 says the following:
"The TMP112 does not support the General Address acquire command."
What does the aquire command mean?
Greetings
Joerg
Hello community,
Greetings
Joerg
It should probably read "General Call Address Acquire" which would be an address acquire command sent to all slaves on the bus via the general call address.
From the TMP112 datasheet:
GENERAL CALL
The TMP112 responds to a two-wire General Call
address (0000000) if the eighth bit is '0'. The device
acknowledges the General Call address and
responds to commands in the second byte. If the
second byte is 00000110, the TMP112 internal
registers are reset to power-up values. The TMP112
command.
