I was wondering. How thick can the container be for the electrodes to live on the exterior of the vessel (as opposed to in direct contact with the liquid)? I assume there is a max thickness for standard PVC before the signal degrades to unusable? Much depends on what drives the DAC I suppose.
I'm trying to eliminate spurious readings due to "muck" buildup on the sensors themselves (if in the liquid). I figure the container itself likely will be less prone to this (I hope), so mounting them on the exterior may be the better solution.
