LDC1614 I2C Extended Start Sequence
Other Parts Discussed in Thread: LDC1614
I have a question about communication to LDC1614 with I2C:
In the datasheet I´ve found that the the LDC1614 needs the following sequence to write registers:
Why do I Need Frame 1 "Serial Bus Address Byte from Master" if I want to attach the LDC1614 simply as slave device? The MCU is master, so I thought that I don´t have to set address because master will initiate data transfer.
Thanks in advance.
Tim Gerbert
