Hi Team
We have some problem on LM25245. Could you help to check our circuit ?
Hi Michael
I use LM95245 in our syste, , When I power up system , The Bios will be read temperature sensor. BIOS will read sensor and temperature >95degree
So BIOS will shutdown our system.
The fail rate : 40% ( 18(fail) / 40(All) ) , We need check this issue
Hi Aaron
Thanky you for your support!! We will modify HW on next version.
BTW
we need use SW for avoid this issue on this version.
Could you help check the Default value for Register 0x10 ? if code is fixed 0x80 , We can pass this issue by BIOS
