FDC2214; Idrive setting by GUI Configuration
Dear all,
I would like to know how to set Idrive by GUI.
I set this value by Sensor Initialization Current at Configuration of GUI.
At this item, I set Idrive by pushing 'Detect Idrive Init' and referring to this Code.
However, I am confused this Code because this Code changed at random under SAME condition.
And I checked this Code changed between 14 ~16 at random.
In this situation, what code should I chose?
Should I chose average code=15? or small side=(13~14)? or large side=(15~16)?
Could you teach me recommended code?
  • Hello Yamamoto-san,
    'Detect Idrive Init' can give you a rough idea of what Idrive is needed to keep the oscillation between 1.2-1.8V. You may use the average value as a starting point. However, different sensors/systems will have different optimal Idrive for sensitivity. If you would like to find the optimal setting, it's best to manually test sensitivity vs Idrive with your setup for a wide range of Idrive.
    Yibo
