TMP112 linux driver issue
Other Parts Discussed in Thread: TMP102, TMP112
My customer use TMP102.c to driver TMP112.
When probe device and read 0x01, it will show bus error msg:
”BUS ERROR:noisy bus/unexpected start/stop tag: msgs(n:2 cur:0 tx) bc(rx:1 tx:1) mode:FIFO slv_addr:0x48 MSTR_STS:0x001121c4 OPER:0x00000010”
Below is driver code, could you please help to check?
[   15.063410] tmp112 5-0048: tmp112_power_init
[   15.067911] i2c-msm-v2 7579000.i2c: msm_bus_scale_register_client(mstr-id:86):0x1e (ok)
[   15.075182] i2c-msm-v2 7579000.i2c: BUS ERROR:noisy bus/unexpected start/stop tag: msgs(n:2 cur:0 tx) bc(rx:2 tx:1) mode:FIFO slv_addr:0x48 MSTR_STS:0x001121c4 OPER:0x00000010
[   15.090537] i2c-msm-v2 7579000.i2c: BUS ERROR:noisy bus/unexpected start/stop tag: msgs(n:2 cur:0 tx) bc(rx:2 tx:1) mode:FIFO slv_addr:0x48 MSTR_STS:0x001121c4 OPER:0x00000000
[   15.106159] tmp112 5-0048: error reading config register
[   15.111463] tmp112: probe of 5-0048 failed with error -3
[   15.116770] tmp112 5-0049: tmp112_power_init
[   15.121224] i2c-msm-v2 7579000.i2c: BUS ERROR:noisy bus/unexpected start/stop tag: msgs(n:2 cur:0 tx) bc(rx:2 tx:1) mode:FIFO slv_addr:0x49 MSTR_STS:0x001121c4 OPER:0x00000010
[   15.136621] i2c-msm-v2 7579000.i2c: BUS ERROR:noisy bus/unexpected start/stop tag: msgs(n:2 cur:0 tx) bc(rx:2 tx:1) mode:FIFO slv_addr:0x49 MSTR_STS:0x001121c4 OPER:0x00000000
[   15.152243] tmp112 5-0049: error reading config register
[   15.157524] tmp112: probe of 5-0049 failed with error -3
[   15.162860] tmp112 5-004a: tmp112_power_init
[   15.167278] i2c-msm-v2 7579000.i2c: BUS ERROR:noisy bus/unexpected start/stop tag: msgs(n:2 cur:0 tx) bc(rx:2 tx:1) mode:FIFO slv_addr:0x4a MSTR_STS:0x001121c4 OPER:0x00000010
[   15.182720] i2c-msm-v2 7579000.i2c: BUS ERROR:noisy bus/unexpected start/stop tag: msgs(n:2 cur:0 tx) bc(rx:2 tx:1) mode:FIFO slv_addr:0x4a MSTR_STS:0x001121c4 OPER:0x00000000
[   15.198334] tmp112 5-004a: error reading config register
[   15.203634] tmp112: probe of 5-004a failed with error -3
[   15.208940] tmp112 5-004b: tmp112_power_init
[   15.213322] i2c-msm-v2 7579000.i2c: BUS ERROR:noisy bus/unexpected start/stop tag: msgs(n:2 cur:1 rx) bc(rx:2 tx:1) mode:FIFO slv_addr:0x4b MSTR_STS:0x001121c4 OPER:0x00000000
[   15.228811] i2c-msm-v2 7579000.i2c: OVER_UNDER_RUN_ERROR: msgs(n:2 cur:0 tx) bc(rx:2 tx:1) mode:FIFO slv_addr:0x4b MSTR_STS:0x001121c4 OPER:0x00000000
[   15.242263] tmp112 5-004b: error reading config register
[   15.247540] tmp112: probe of 5-004b failed with error -110
