TMP708 How to setting temperature threshold at 125°
Other Parts Discussed in Thread: LM57
We need to setting threshold at 125° , But , Calculate rule is Error (-1.46 K) , Pls help to comment  How to setting temperature threshold at 125° , thanks!
  • Hi James,
    Can you try using a 500Ohm resistor and below. This temperature switch was meant to be used between 60C and 100C and the Rset equation was meant to reflect that. If this does not meet your need we also have another resistor programmable switch called the LM57 which will fulfill your 125C trip point.
    -Michael Wong
