TDC1000-TDC7200 EVM Load Config error
Other Parts Discussed in Thread: TDC7200, TDC1000
I Load TDC7200 config file as below but have error window pops up. Would you kindly help to check what's happened?
Thanks.
tdc1000_7200_concentration_cells_saleskit_2_2015.txt
tdc1000_7200_level_cells_saleskit_2_2015.txt
  • You can use the enclosed files
    TDC1000_Config0                         41
    TDC1000_Config1                         41
    TDC1000_Config2                         04
    TDC1000_Config3                         04
    TDC1000_Config4                         5F
    TDC1000_TOF-1                           03
    TDC1000_TOF-0                           FF
    TDC1000_Error_Flags                     00
    TDC1000_Timeout                         23
    TDC1000_Clock_Rate                      00
    TDC1000_Conts_Trigger                   01
    TDC7200_Config1                         02
    TDC7200_Config2                         40
    TDC7200_Interrupt_Status                07
    TDC7200_Interrupt_Mask                  07
    TDC7200_Coarse_Cntr_Ov_H                FF
    TDC7200_Coarse_Cntr_Ov_L                FF
    TDC7200_Clock_Cntr_Ov_H                 FF
    TDC7200_Clock_Cntr_Ov_L                 FF
    TDC7200_Clock_Cntr_Stop_Mask_H          00
    TDC7200_Clock_Cntr_Stop_Mask_L          00
    TRIGGER_UPDATE_FREQ                     0004
    TDC_AVG/STDEV_NUM_ELEMS                 0032
    SAVE_GRAPH_DATA_TO_FILE                 00
    FLOW_MODE_SELECT                        00
    Y-SCALE_CENTER                          0032
    X-SCALE_RANGE                           0032
    MEASURE_RTD1                            00
    SAVE_RESULT_REGR_TO_FILE                00
    GRAPH_MULTI_STOPS                       00
    TDC_SELECT                              00
    TEMP_RTD_SELECT                         00
    TEMP_RTD_MODE                           01
    TEMP_AVG/STDEV_NUM_ELEMS                000A
    SAVE_TEMP_DATA                          00
    GRAPH_YMAX_DATA                         00000000000128A9
    GRAPH_YMIN_DATA                         0000000000012845
    TDC1000-HV_DRV_EN1                      00
    TDC1000-HV_DRV_EN2                      00
    HV_DRV_EN1_Period                       001E
    HV_DRV_EN2_Period                       001E
    ENABLE_POWER_CYCLE                      00
    CLK_FREQ_(1-16MHz)                      8.000000
    CLK_SOURCE_SEL                          00
    CPU_CLK_FREQ                            05
    CPU_CLK_EN                              00
    TDC1000-HV_BST_PWR_EN                   00
    HV_BST_PWR_EN_Period                    0000
    FWD2REV_FLOW_DELAY                      0000
    TDC1000-IMPE_MATCH_EN                   00
    ENABLE_UART_STREAM                      00
    ENABLE_MSP430TIMER_TDC                  00
    TDC1000_Config0                         41
    TDC1000_Config1                         41
    TDC1000_Config2                         00
    TDC1000_Config3                         04
    TDC1000_Config4                         5F
    TDC1000_TOF-1                           03
    TDC1000_TOF-0                           FF
    TDC1000_Timeout                         23
    TDC7200_Config1                         02
    TDC7200_Config2                         40
    FLOW_MODE_SELECT                        00
    Y-SCALE_CENTER                          0000
    X-SCALE_RANGE                           0032
    MEASURE_RTD1                            00
    TDC_SELECT                              00
    TEMP_RTD_SELECT                         00
    TEMP_RTD_MODE                           01
    SAVE_TEMP_DATA                          00
    GRAPH_YMAX_DATA                         0000000000029810
    GRAPH_YMIN_DATA                         0000000000004E20
    CLK_SOURCE_SEL                          00
    CPU_CLK_FREQ                            05
    CPU_CLK_EN                              00
    Vishy
