TDC1000: How to test connectivity between wire and piezo-ceramic transducer?
Part Number: TDC1000
I have mounted a piezo-ceramic ultrasonic transducer ((MODEL # SMD10T2R111WL, Vendor Website: https://www.steminc.com/PZT/en/piezo-ceramic-disc-10x2mm-r-215-khz-wire-leads-smd10t2r111wl)) under a plastic tank using epoxy (please see the attached picture). I am trying to confirm that the wire did not get detached from the transducer while mounting. Is there a way to test it. The two wires that are soldered to the transducer are not connected so there is no way to check the continuity of the wires using multi meter short circuit test. Thanks for your help in advance.
Best, Niloy.
