Other Parts Discussed in Thread: AFE4403, AFE4403EVM
why i can not to get the red led signal (sfh7050:Upper part of the wrist)? i was trying every single configuration and i can not, however IR signal it is in good quality. even green signal.
Hi i am here again.
i have used discrete component in afe4403 i put it in this socket.
i am using the same sensor but i cant get the red signal.
i dont know how to get a red clean signal in wrist.
picture Blue signals were obtained from afe4403 in the socket. the pictures in red were obtained from your software and afe4403EVM <-- this last were in wrist so i dont understand.
if we compare your afe4403evm signals and the afe4403 in the socket that i have implemented you can see a noisy signal i mean the signal are not as clean as yours so i dont know what the problem is, What i see is i high level noise in what i have implemented compare with yours.
what can you recomend me?
I have implemented a passband filter for the signals and i have not problem with green and ir because as you can see the noise is too big if we compare ir with the signal about spectrum analisys i will do it, and you are right maybe is a design problem if we are talking about the socket and i am using discrete components.
the problem is not that i can not to filter this signal the problem is that in the signal is mounted multiples of 40 hertz signals and i dont understand the reason.
