Hi all,
I want to use AWR1642 EVM to evaluate following conditions and base on mmWave_SDK_01_00_00_05.
May I know the blank column value and config files for each condition?
Thanks in advance.
B.R.
OC
Hi Omin,
Your best option to quickly obtain config files is to use the mmWave Demo Visualizer found at:
https://dev.ti.com/gallery/view/534566/mmWave_Demo_Visualizer/
Fill out your corresponding configuration requirements and at the bottom of the page select Save Config to PC.
I cannot comment on what your Mid range values should be as that depends on your application but I would suggest choosing appropriate values in between your Near and Far Range requirements.
Hope this helps,
Adrian
