AWR1642: How to change configuration?
Part Number: AWR1642
Please tell me whether there is a way to rewrite the configuration file. (I'd like to lower the output for evaluation)
    First just to make sure I understand your usage scenario , you are using the mmw demo application and you want to change the configuration file in the demo ? Are you trying to lower the TX output power?
    If my above understanding is correct then the TX output power can be reduced by setting the "Tx output power back-off code for tx antennas" parameter in the ProfileCfg command in the CLI. A value of 0 implies max output power , you can reduce the power in steps on 1 dB , each LSB corresponding to 1dB. ie a value of 1 corresponds to 1dB reduction in the TX output power .
    Vivek
  • Vivek san
    Thank you very match.
    We were able to adjust the TX power.
    Best regards,.
