I've simulated a linear position sensing configuration consisting of a stretched PCB sensor coil and a longitudinally moving target (as described in the app notes) in a 3D field solver and found that I get a significantly greater change of inductance over the length of displacement when I use a ferrite material for the target than with a highly conductive (non-ferrous) solid metal alloy like brass. I do understand the different causes for the inductance change (high permeability in case of the ferrite vs. mutual inductance due to eddy currents). As long as I don't mind what's causing the inductance change and all I want is to maximize resolution for the same size coil and target, the ferrite would be the more attractive choice. Any reasons not to use a ferrite target?
Thanks!
Matthias
