Other Parts Discussed in Thread: OPT9221
I am having some problem in getting the data stream from the device. It was working before, and then it just stop working. The master LED stay solid green while the TFC led remain off all time. I found a coupple of different post in the forum regarding to the same issue, but i wans't able to find a useful solution yet. Can anyone help me on this?
The following is the log files from the VoxelViewer:
Voxel Viewer v0.7.0
Texas Instruments Inc.
INFO: TintinCDKCamera: Board revision = 2.0
INFO: ParameterDMLParser: Found register map with name 'OPT9221' (vPG1P0)
INFO: TintinCDKCamera: Received 43848 bytes from EEPROM in 1.97445 s
INFO: Data2DCodec: Original number of 8-bit offsets = 1194
INFO: Data2DCodec: Number of invalid pixels in original data = 0
INFO: Data2DCodec: Current number of 8-bit offsets = 1194
ERROR: DepthCamera: Could not set the camera profile to '70'
ERROR: DepthCamera:Could not get value for parameter TintinCDKCamera(0::0451:9105::938614940321).vco_freq1
ERROR: DepthCamera: Failed to update value for parameter 'mod_freq1'
ERROR: DepthCamera:Could not get value for parameter TintinCDKCamera(0::0451:9105::938614940321).vco_freq2
ERROR: DepthCamera: Failed to update value for parameter 'mod_freq2'
ERROR: DepthCamera: Failed to update value for parameter 'sysclk_in_freq'
ERROR: DepthCamera: Failed to update value for parameter 'quad_cnt_max'
ERROR: DepthCamera: Failed to update value for parameter 'vco_freq2'
ERROR: DepthCamera: Failed to update value for parameter 'vco_freq1'
ERROR: CameraSystem: Could not refresh parameters for TintinCDKCamera(0::0451:9105::938614940321).
ERROR: DepthCamera:Could not get value for parameter TintinCDKCamera(0::0451:9105::938614940321).vco_freq1Traceback (most recent call last):
File "D:\Anand\Work\Code\voxel-sdk\voxel-viewer\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.docks.FrequentlyUsedParametersDockWidget", line 93, in updateView
File "D:\Anand\Work\Code\voxel-sdk\voxel-viewer\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.docks.FrequentlyUsedParametersDockWidget", line 46, in showParam
File "D:\Anand\Work\Code\voxel-sdk\voxel-viewer\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.views.ParameterHandlerROI", line 127, in __init__
File "D:\Anand\Work\Code\voxel-sdk\voxel-viewer\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.views.ParameterHandlerROI", line 259, in init
File "D:\Anand\Work\Code\voxel-sdk\voxel-viewer\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.views.XYSpinBox", line 35, in setRange
OverflowError
CalibrationStatus: Calibration invalid for - Temperature.
ERROR: ToFCameraBase: Could not get current frame rate
INFO: ToFCameraBase: Starting with 388x388@0fps
ERROR: TintinCDKCamera: Could not get current frame rate
