Other Parts Discussed in Thread: MATHLIB
I am working on implement some add-on based on mmw_demo app(SDK 1.0.0.05).
I just add a dozen lines of code on DSS but got the some error as below, I also post my last good build log to give you an idea where the image size stands. Please help me to how to resolve this error.
Xinsi Lin
==============Build failed=======================================
[C674 Device/Type: awr16xx/xwr16xx] Building file: dss/dss_main.c
"C:/ti/mathlib_c674x_3_1_2_1/packages/ti/mathlib/src/common/common.h", line 55:
warning #48-D: incompatible redefinition of macro "TRUE" (declared at line 322 o
f "c:/ti/xdctools_3_50_01_12_core/packages/xdc/std.h")
"C:/ti/mathlib_c674x_3_1_2_1/packages/ti/mathlib/src/common/common.h", line 56:
warning #48-D: incompatible redefinition of macro "FALSE" (declared at line 319
of "c:/ti/xdctools_3_50_01_12_core/packages/xdc/std.h")
[C674 Device/Type: awr16xx/xwr16xx] Building file: dss/dss_data_path.c
"dss/dss_data_path.c", line 1784: warning #128-D: expected a statement
cl6x -mv6740 --abi=eabi -g --define=SOC_XWR16XX --display_error_number --diag_wa
rning=225 --diag_wrap=off -z --reread_libs --warn_sections --ram_model -iC:/ti/c
csv7/tools/compiler/ti-cgt-c6000_8.1.3/lib -iC:/ti/mmwave_sdk_01_00_00_05/packag
es/ti/drivers/osal/lib -iC:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/soc/li
b -iC:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/uart/lib -iC:/ti/mmwave_sdk
_01_00_00_05/packages/ti/drivers/crc/lib -iC:/ti/mmwave_sdk_01_00_00_05/packages
/ti/drivers/mailbox/lib -iC:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/adcbu
f/lib -iC:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/edma/lib -iC:/ti/mmwave
_sdk_01_00_00_05/packages/ti/control/mmwavelink/lib -iC:/ti/mmwave_sdk_01_00_00_
05/packages/ti/control/mmwave/lib -iC:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dspli
b/lib -iC:/ti/mathlib_c674x_3_1_2_1/packages/ti/mathlib/lib -iC:/ti/mmwave_sdk_0
1_00_00_05/packages/ti/alg/mmwavelib/lib -llibosal_xwr16xx.ae674 -llibsoc_xwr16x
x.ae674 -llibcrc_xwr16xx.ae674 -llibuart_xwr16xx.ae674 -llibmailbox_xwr16xx.ae67
4 -llibmmwavelink_xwr16xx.ae674 -llibmmwave_xwr16xx.ae674 -llibadcbuf_xwr16xx.ae
674 -llibedma_xwr16xx.ae674 -llibmmwavealg_xwr16xx.ae674 -ldsplib.ae64P -lmathli
b.ae674 \
-ldss/mmw_configPkg_xwr16xx/linker.cmd --map_file=xwr16xx_mmw_demo_dss.m
ap obj_xwr16xx/dss_main.oe674 obj_xwr16xx/dss_config_edma_util.oe674 obj_xwr16xx
/dss_data_path.oe674 obj_xwr16xx/gen_twiddle_fft16x16.oe674 obj_xwr16xx/gen_twid
dle_fft32x32.oe674 \
C:/ti/mmwave_sdk_01_00_00_05/packages/ti/platform/xwr16xx/c674x_linker.c
md dss/dss_mmw_linker.cmd -lrts6740_elf.lib -o xwr16xx_mmw_demo_dss.xe674
<Linking>
"dss/dss_mmw_linker.cmd", line 44: warning #10068-D: no matching section
"dss/dss_mmw_linker.cmd", line 36: error #10099-D: program will not fit into ava
ilable memory. run placement with alignment fails for section ".fastCode" size
0x3f60 . Available memory ranges:
L1PSRAM size: 0x4000 unused: 0x4000 max hole: 0x4000
error #10010: errors encountered during linking; "xwr16xx_mmw_demo_dss.xe674" no
t built
>> Compilation failure
gmake: *** [dssDemo] Error 1
=================Last good build==================================
b.ae674 \
<Linking>
cp -f dss/mmw_configPkg_xwr16xx/package/cfg/dss_mmw_pe674.rov.xs dss_mmw_pe674.r
ov.xs
Built the DSS Millimeter Wave Demo [Preparing the BIN Format]
Parsing the input object file, xwr16xx_mmw_demo_dss.xe674.
Appending zeros 8463904
Appending zeros 8471568
Appending zeros 8481400
Appending zeros 8482024
File conversion complete!
Built the DSS Millimeter Wave OUT & BIN Formats
C:/ti/mmwave_sdk_01_00_00_05/packages\scripts\ImageCreator\xwr16xx\multicore_ima
ge_generator\MulticoreImageGen.exe LE 37 0x01000005 xwr16xx_mmw_demo.bin 0x35510
000 xwr16xx_mmw_demo_mss.bin 0xb5510000 C:/ti/mmwave_sdk_01_00_00_05/packages/..
/firmware/radarss/xwr16xx_radarss_rprc.bin 0xd5510000 xwr16xx_mmw_demo_dss.bin
Number of Input Files 3
Number of zeros 24
Number of zeros 8
Number of zeros 56
call C:/ti/mmwave_sdk_01_00_00_05/packages\scripts\ImageCreator\xwr16xx\crc_mult
icore_image\crc_multicore_image.exe xwr16xx_mmw_demo.bin xwr16xx_mmw_demo.bin.tm
p
size of App Image is 417024 bytes
cur_crc_read_addr 128
cur_crc_read_addr 107968
cur_crc_read_addr 244160
Failed to remove CRC temp file
perl C:/ti/mmwave_sdk_01_00_00_05/packages\scripts\ImageCreator\xwr16xx\append_b
in_crc\gen_bincrc32.pl xwr16xx_mmw_demo.bin
>>>> Binary CRC32 = e514adeb <<<<
>>>> Total bytes in binary file 417028 <<<<
Built the mmw Demo Flash Binary
