AWR1443BOOST: Packaging for Field Trials
Part Number: AWR1443BOOST
Other Parts Discussed in Thread: AWR1443,
hello
Which packaging material/container should be used to carry out Outdoor Field Trials with AWR1443 BOOST? Is there any specific requirement for that?
Prashant Koparde
  • Hello Prashant,
    I don't think I understand your question. Are you asking about a container or mount for the AWR1443BOOST or are you looking for a container for your detected objects.
    The mmWave Sensors will see through paper, cardboard, and plastics with relative ease while metal objects are highly reflective and will be detected as objects.
    Cheers,
    Akash
  • hello Akash
    I am looking for container or mount for AWR1443BOOST (RADOME). Can you share any available documentation on this ?
  • Hello again Prashant,
    No further documentation exists for mounting but I'd be happy to provide you with some advice. Would you be able to post pictures of your surface or application?
    I can tell you about a couple of mounts I have put together:
    For the Water and Ground demo we used a plank of plexiglass with the AWR1443BOOST mounted on four standoffs:
    The Drone demo had a custom cut piece of plexiglass with the EVM mounted underneath:
    I will let you know that most of the mounts that have been made have used plexiglass and standoffs from a kit such as this () or similar.
    Cheers,
    Akash
