TDC1000-TDC7200EVM: water flow metering
Part Number: TDC1000-TDC7200EVM
hi am working on water flow metering in some of the forums i got to know that transducers can be mounted at an angle of 45 degree may i know what should be the medium of materia in between the space left between pipe and transducer surface.
  • Hello Rashmi,
    The material between your transducer and the side of the pipe should match the pipe material as closely as possible. However, I will say that this kind of question is not our area of expertise. I strongly suggest that you contact your transducer manufacturer to get a more comprehensive answer.
