I want to know the height of fuel and water in the underground tank using magnetostrictive level sensor. Does TI have reference design for magnetostrictive level sensor? Thanks
Brother,
You are right, I am worried about using "Capacitive-Based Liquid Level Sensing Sensor" in the explosive area because the electrode of sensor is in direct contact with the fuel, and if there is a little spark it will result in an explosion. Wire, nail or other small metals that accidentally enter the tank during the charging process, will trigger a spark?
I've tried using "Hall Effect Sensor", the constraint is the accuracy of the measurement results that are affected from the temperature. The temperature change will change the output voltage of the sensor, so it will affect the accuracy of the measurement results.
"Magnetostrictive level sensor" I think is the best choice, sending current-pulse to magnetostrictive wire and reading the return pulse. The pulse will be back when it comes to a magnet-float.
Thank You.
