Hi ,
Our customer have problem.
Data can not be read rarely when SCLK is set to High from before power-on.
If SCLK should not be set high when power is turned on, when should they turn SCLK high?
Kenji/Japan Disty
Hi ,
Kenji/Japan Disty
Hi Kenji-san,
Thank you for reaching out to us. There is no issue when biasing the SCL and SDA pins before the device is turned ON. The communication can start immediately before the power supply pin reaches specified voltage. However, assuming the power supply ramp has met the specified voltage. During at power-up, the temperature result register will be zero until the first conversion completes once the power is valided. The conversion time takes about 35ms max.
Hope this helps. Let me know if you have further question.
Aaron
