FDC2214 can detect the maximum distance? whether it can reach 300mm
The detection range of the FDC2214 depends on 3 primary factors:
And always the best way to determine the detection range is to buy an FDC2214EVM and test with larger sensor surface area. Sensors can be constructed out of a wide range of conductors including a copper plane from a PCB layer, aluminum foil, or copper tape for example.
Hope this helps point you in the right direction!
Luke
