Other Parts Discussed in Thread: AWR1642
Cortex_R4_0: Trouble Removing Breakpoint with the Action "Process CIO" at 0x132c6: (Error -1066 @ 0x132C6) Unable to set/clear requested breakpoint. Verify that the breakpoint address is in valid memory. (Emulation package 6.0.628.3)
Cortex_R4_0: Error: (Error -261 @ 0x0) Invalid response was received from the XDS110. (Emulation package 6.0.628.3)
Cortex_R4_0: Unable to determine target status after 20 attempts
Cortex_R4_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
IcePick_M_0: Error: (Error -261 @ 0xFFFFFEFB) Invalid response was received from the XDS110. (Emulation package 6.0.628.3)
