IWR1433BOOST:How to Realize High-precision Level Measurement of Transparent Liquids ?
Hi,team
Thank you very much for your help!
I have a work to measure the level of a transparent liquid , How to Realize High-precision Level Measurement of Transparent Liquids ?
In the experiment, I found that the radar signal will return through the transparent liquid and return at the bottom of the container. As a result, it is impossible to measure the liquid level. I would like to improve on the basis of lab0004-high-accuracy-14xx. This requirement can be met , is it possible? How to modify the program?
Best Wishes,
Jacky Ye
  • Hi Jacky,
    The High Accuracy 14xx Demo returns the strongest peak that is found in the range profile. While your largest peak might be the bottom of your tank, you can simply filter out results at this distance or beyond and return the next strongest peak.
    Cheers,
    Akash
