TMP235: Use of temperature sensor on PCB
Part Number: TMP235
I need to measure the temperature of components on the PCB by placing the sensor just on that component's PCB Polygon so as the temperature rise can be sensed as early as possible for shutdown and avoid component failures. The PCB placement is not mentioned in the application note, as which point should be placed nearer to the heat measurement spot.
