Hello team,
I have three questions about LDC1614 as below. Could you please support below?
1.
LDC1614 datasheet says "When the DATAx_MSB register is read, the contents of both the DATAx_MSB and DATAx_LSB registers are updated with the new conversion data".
Does this statement mean for example if we dont access MSB register but LSB register, MSB and LSB registers are not updated and what we readout from the LSB register is always same value?
2.
Datasheet also mentions internal shadow register and its data is updated to data registers. I think there is a little time is needed to transfer data from shadow register to data registers. Is there prohibit readout timing with considering the transferring timing?
3.
I would like to read out data in about 500us, however EVM GUI seems to support only down to 100ms update rate. Is there anyway to achive 500us update rate in EVM? Or do you have any sample code for this?
