Other Parts Discussed in Thread: IWR1642, AWR1642, TEST2
Hi TI team,
What is the official power consumption for the IWR1443 before sensorStart and after sensorStop ? Same question for the IWR1642.
Given that there are different radar - mmwave sensor configurations, there is no specific "official power consumption", there are several references:
a) In section 5.2 of the datasheet there is a maximum current and voltage by rail.
b) there is a power spreadsheet for specific parameters, this is downloadable from the TI web page.
c) in the datasheet for AWR1642, there is a specific power vs use case table in section 5.
d) if you have a specific industrial use case, you will have a specific power, TIDEP 0091 for level sensing has some values in the design guide.
We are working to reduce the 1443 power for Level Sensing. Related to (d) you could measure the EVM 5v input current, or PMIC rail currents with a wireloop
in series with the PMIC output inductor,
Joe Quintal
Thanks Joe,
But I wanted the power consumption number before "sensorStart" command is sent - and after "sensorStop" has been issued - which to me represents a less-than-active mode. I can measure but wanted to understand what the official number is and if this state can be referred to as 'standby' ?
Thanks Joe, I will make the measurements.
Am more interested in the current draw after boot and before the RF is switched on and then after it is switched off. Understand the implications of BSS location during boot, as well as the application boot/copy itself.
