IWR1443BOOST: SPI example code for the IWR1443?
Part Number: IWR1443BOOST
Other Parts Discussed in Thread: IWR1443, TIDEP-0091
I am trying to send the range data from IWR1443BOOST to an external processor over SPI. I have followed Jitendra's steps mentioned in the original form, and my code compiles.
However, when transmitting SPI data, everything freezes at Spi_transfer(); the IWR1443 stops chirping, and becomes unresponsive.
I have looked at the following forms and followed their steps including using the Level Sensing Data example. I have tried putting the Spi_transfer() function under the SPI mmw_transmitprocessdata as recommended.
2 questions:
Is there any example code that uses the IWR1443 as a SPI master/slave?
Do you know what would cause everything to freeze during the Spi_transfer() function?
Thank you
-Scott
Reference Forms:
https://e2e.ti.com/support/sensor/mmwave_sensors/f/1023/t/614263?CCS-AWR1443BOOST-Adding-SPI-functionality-to-the-mmw-demo
http://e2e.ti.com/support/sensor/mmwave_sensors/f/1023/t/617609
https://e2e.ti.com/support/sensor/mmwave_sensors/f/1023/t/681291?CCS-AWR1443-Interfacing-AWR1443-with-MSP432-through-SPI
