AWR1642: How to continuous read GPADC data out?
Part Number: AWR1642
Hello, I've read https://e2e.ti.com/support/sensor/mmwave_sensors/f/1023/t/674427 .
I tried to replace mss_main.c with mss_main_GPADC.c in mmWaveRadar demo, but I found the event RL_RF_AE_GPADC_MEAS_DATA_SB will be called only once.
Is there a way to configure gpadc to continous sampling?
And if i call rlSetGpAdcConfig() at the beginning of MmwDemo_mssInitTask(), it will cause an error with return code = -2, is the function must be called befor mmWaveLib be initialized?
At last, I've met some situation that if I called rlSetGpAdcConfig() after sync was reched but before mmWaveLib_config() is called, the Mailbox_write() function which is called in cli will failed with code = -2212. If I add a Task_sleep(1000); after rlSetGpAdcConfig() is called, everything is right.
What's wrong with this? Thank you!
