Q - High-Temperature sensing options? (+200C)
Other Parts Discussed in Thread: XTR108
Hi there -
I'm looking for a relatively low-cost, moderate accuracy circuit that will sense temperatures up to +200C (+400F).  The IC temperature sensors I have found so far seem to be limited to +125C, although I did locate a sensor from another manufacturer that claims to sense to +150C.
What are my options for a sensor circuit that will operate to +200C?  Am I limited to a thermistor-based design, or are there other options?
Thanks;
Randy
  • I recommend looking at RTD’s.  This is the most accurate temperature sensing solution for the temperature range you are looking at.  The XTR108 is a good way of doing signal conditioning on RTD’s.
    Art Kay
