I am seeing the following image indicating that fluid is 1014 mm away from sensor when fluid is actually 480 mm away.
1) Any idea how I could resolve this issue?
2) What is the minimum fluid distance this device can detect?
DJ
DJ
Hi Akash,
Per your suggestion, I tried with a bucket with a wider diameter (~30cm). As you can see from the photo, the device was approximately 10 cm away from the fluid level. I also placed a plexiglass as indicated from the user-guide. Still the reading was bouncing between 1100 mm to 1120 mm. Even considering the 100 degrees of beam width, it should be able to detect something that's ~10 cm away.. Any idea why it would be off by this much?
DJ
