AWR1642BOOST: AWR1642BOOST: EVM stack up question
Part Number: AWR1642BOOST
I found two different AWR1642BOOST EVM Board resource as followings from the e2e and ti website
1. www.ti.com/.../spracg5.pdf
2. www.ti.com/.../sprr261
From these sheets, there have slight difference stackups at thickness of some layers. Which one should I comply with since I assume RF signal on the top of RO4835 have exactly definition on simulation else.
  • Hello Cheng,
    Are you referring to slight difference in the processed thickness of the L1 copper? That would not make much difference in the impedance . Either of the ones can be used. Different manufactures will have a slightly different copper thickness due to processing differences. But both are almost the same in performance
    vivek
