Part Number: OPT8241-CDK-EVM
Tool/software: Linux
Hello
I follow the instructions from github: github.com/.../Build-from-source-on-ARM-(Raspberry-Pi-3), however, I met some problems like this: I’m having a bit problem when i try to run cmake-gui .. in “build” file. I made build folder like this “/Software/voxelsdk/build” and after typing cmake-gui .. i get this problem “libEGL warning: DRI2: failed to authenticate” and after that a pop-up comes up and tells me to select a source code. I tried to make build folder in different directories but the error is the same. i’m kinda new to this so i don’t know where i made the mistake. Until this step everything worked out smoothly.
Some others also have the same problem, wish for a reply, thanks!
