Other Parts Discussed in Thread: AWR1443
Tool/software: TI-RTOS
I'm implementing the application for awr1443 board and using sdk 1.2.0.5, loads chirp profiles from memory(stored globle structure in same file /utils/cli/cli.c). As TI implementation, receive command from COM port parse to device instead of this, i'm parsing command from globle structure. Here is two senario noted:
1. Disable uart_read and parse all command, but not single command parse. find attached src file cli_impl1.c.
2. keep uart_read, which requires 'enter' key press through command line port, then only it parse command. find attached src file cli_impl2.c.
In our application, we want to parse all command of globle structure when power-on, also keep uart_read open to control from command line
Hope TI will anlyse and response above SDK issue.
/* * @file cli.c * * @brief * CLI Utility implementation * * \par * NOTE: * (C) Copyright 2016 Texas Instruments, Inc. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /************************************************************************** *************************** Include Files ******************************** **************************************************************************/ /* Standard Include Files. */ #include <stdint.h> #include <stdlib.h> #include <stddef.h> #include <string.h> #include <stdio.h> /* BIOS/XDC Include Files. */ #include <xdc/std.h> #include <ti/sysbios/knl/Task.h> /* mmWave SDK Include Files: */ #include <ti/common/sys_common.h> #include <ti/drivers/uart/UART.h> #include <ti/utils/cli/cli.h> #include <ti/utils/cli/include/cli_internal.h> /************************************************************************** *************************** Global Variables ***************************** **************************************************************************/ /** * @brief Global variable which tracks the CLI MCB */ CLI_MCB gCLI; const char *defaultConfigCommands[] = { "sensorStop", "flushCfg", "dfeDataOutputMode 1", "channelCfg 15 7 0", "adcCfg 2 1", "adcbufCfg 0 1 0 1", "profileCfg 0 77 267 7 57.14 0 0 70 1 240 4884 0 0 30", "chirpCfg 0 0 0 0 0 0 0 1", "chirpCfg 1 1 0 0 0 0 0 4", "chirpCfg 2 2 0 0 0 0 0 2", "frameCfg 0 2 16 0 100 1 0", "lowPower 0 0", "guiMonitor 1 1 0 0 0 1", "cfarCfg 0 2 8 4 3 0 1280", "peakGrouping 1 1 1 1 229", "multiObjBeamForming 1 0.5", "clutterRemoval 1", "calibDcRangeSig 0 -5 8 256", "compRangeBiasAndRxChanPhase 0.0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0", "measureRangeBiasAndRxChanPhase 0 1.5 0.2", "CQRxSatMonitor 0 3 5 123 0", "CQSigImgMonitor 0 119 4", "analogMonitor 1 1", "sensorStart" }; /************************************************************************** **************************** CLI Functions ******************************* **************************************************************************/ /** * @b Description * @n * The function is the HELP generated by the CLI Module * * \ingroup CLI_UTIL_INTERNAL_FUNCTION * * @retval * Not Applicable. */ static int32_t CLI_help (int32_t argc, char* argv[]) { uint32_t index; /* Display the banner: */ CLI_write ("Help: This will display the usage of the CLI commands\n"); CLI_write ("Command: Help Description\n"); /* Cycle through all the registered CLI commands: */ for (index = 0; index < gCLI.numCLICommands; index++) { /* Display the help string*/ CLI_write ("%s: %s\n", gCLI.cfg.tableEntry[index].cmd, (gCLI.cfg.tableEntry[index].helpString == NULL) ? "No help available" : gCLI.cfg.tableEntry[index].helpString); } /* Is the mmWave Extension enabled? */ if (gCLI.cfg.enableMMWaveExtension == 1U) { /* YES: Pass the control to the extension help handler. */ CLI_MMWaveExtensionHelp (); } return 0; } /** * @b Description * @n * This is the CLI Execution Task * * \ingroup CLI_UTIL_INTERNAL_FUNCTION * * @retval * Not Applicable. */ static void CLI_task(UArg arg0, UArg arg1) { uint8_t cmdString[256]; char* tokenizedArgs[CLI_MAX_ARGS]; char* ptrCLICommand; char delimitter[] = " \r\n"; uint32_t argIndex; CLI_CmdTableEntry* ptrCLICommandEntry; int32_t cliStatus; uint32_t index; uint32_t cmdcnt = 0U; /* Do we have a banner to be displayed? */ if (gCLI.cfg.cliBanner != NULL) { /* YES: Display the banner */ CLI_write (gCLI.cfg.cliBanner); } /* Loop around forever: */ while (cmdcnt < 25) { /* Demo Prompt: */ CLI_write (gCLI.cfg.cliPrompt); /* Reset the command string: */ memset ((void *)&cmdString[0], 0, sizeof(cmdString)); /* Read the command message from the UART: */ // UART_read (gCLI.cfg.cliUartHandle, &cmdString[0], (sizeof(cmdString) - 1)); /* Reset all the tokenized arguments: */ memset ((void *)&tokenizedArgs, 0, sizeof(tokenizedArgs)); argIndex = 0; // ptrCLICommand = (char*)&cmdString[0]; ptrCLICommand = (char*)defaultConfigCommands[cmdcnt]; cmdcnt++; /* comment lines found - ignore the whole line*/ if (cmdString[0]=='%') { CLI_write ("Skipped\n"); continue; } /* Set the CLI status: */ cliStatus = -1; /* The command has been entered we now tokenize the command message */ while (1) { /* Tokenize the arguments: */ tokenizedArgs[argIndex] = strtok(ptrCLICommand, delimitter); if (tokenizedArgs[argIndex] == NULL) break; /* Increment the argument index: */ argIndex++; if (argIndex >= CLI_MAX_ARGS) break; /* Reset the command string */ ptrCLICommand = NULL; } /* Were we able to tokenize the CLI command? */ if (argIndex == 0) continue; /* Cycle through all the registered CLI commands: */ for (index = 0; index < gCLI.numCLICommands; index++) { ptrCLICommandEntry = &gCLI.cfg.tableEntry[index]; /* Do we have a match? */ if (strcmp(ptrCLICommandEntry->cmd, tokenizedArgs[0]) == 0) { /* YES: Pass this to the CLI registered function */ cliStatus = ptrCLICommandEntry->cmdHandlerFxn (argIndex, tokenizedArgs); if (cliStatus == 0) { CLI_write ("Done\n"); } else { CLI_write ("Error %d\n", cliStatus); } break; } } /* Did we get a matching CLI command? */ if (index == gCLI.numCLICommands) { /* NO matching command found. Is the mmWave extension enabled? */ if (gCLI.cfg.enableMMWaveExtension == 1U) { /* Yes: Pass this to the mmWave extension handler */ cliStatus = CLI_MMWaveExtensionHandler (argIndex, tokenizedArgs); } /* Was the CLI command found? */ if (cliStatus == -1) { /* No: The command was still not found */ CLI_write ("'%s' is not recognized as a CLI command\n", tokenizedArgs[0]); } } } } /** * @b Description * @n * Logging function which can log the messages to the CLI console * * @param[in] format * Format string * * \ingroup CLI_UTIL_EXTERNAL_FUNCTION * * @retval * Not Applicable. */ void CLI_write (const char* format, ...) { va_list arg; char logMessage[256]; int32_t sizeMessage; /* Format the message: */ va_start (arg, format); sizeMessage = vsnprintf (&logMessage[0], sizeof(logMessage), format, arg); va_end (arg); /* Log the message on the UART CLI console: */ if (gCLI.cfg.usePolledMode == true) { /* Polled mode: */ UART_writePolling (gCLI.cfg.cliUartHandle, (uint8_t*)&logMessage[0], sizeMessage); } else { /* Blocking Mode: */ UART_write (gCLI.cfg.cliUartHandle, (uint8_t*)&logMessage[0], sizeMessage); } } /** * @b Description * @n * This is the function which is used to initialize and setup the CLI * * @param[in] ptrCLICfg * Pointer to the CLI configuration * * \ingroup CLI_UTIL_EXTERNAL_FUNCTION * * @retval * Success - 0 * @retval * Error - <0 */ int32_t CLI_open (CLI_Cfg* ptrCLICfg) { Task_Params taskParams; uint32_t index; /* Sanity Check: Validate the arguments */ if (ptrCLICfg == NULL) return -1; /* Initialize the CLI MCB: */ memset ((void*)&gCLI, 0, sizeof(CLI_MCB)); /* Copy over the configuration: */ memcpy ((void *)&gCLI.cfg, (void *)ptrCLICfg, sizeof(CLI_Cfg)); /* Cycle through and determine the number of supported CLI commands: */ for (index = 0; index < CLI_MAX_CMD; index++) { /* Do we have a valid entry? */ if (gCLI.cfg.tableEntry[index].cmd == NULL) { /* NO: This is the last entry */ break; } else { /* YES: Increment the number of CLI commands */ gCLI.numCLICommands = gCLI.numCLICommands + 1; } } /* Is the mmWave Extension enabled? */ if (gCLI.cfg.enableMMWaveExtension == 1U) { /* YES: Initialize the CLI Extension: */ if (CLI_MMWaveExtensionInit (ptrCLICfg) < 0) return -1; } /* Do we have a CLI Prompt specified? */ if (gCLI.cfg.cliPrompt == NULL) gCLI.cfg.cliPrompt = "CLI:/>"; /* The CLI provides a help command by default: * - Since we are adding this at the end of the table; a user of this module can also * override this to provide its own implementation. */ gCLI.cfg.tableEntry[gCLI.numCLICommands].cmd = "help"; gCLI.cfg.tableEntry[gCLI.numCLICommands].helpString = NULL; gCLI.cfg.tableEntry[gCLI.numCLICommands].cmdHandlerFxn = CLI_help; /* Increment the number of CLI commands: */ gCLI.numCLICommands++; /* Initialize the task parameters and launch the CLI Task: */ Task_Params_init(&taskParams); taskParams.priority = gCLI.cfg.taskPriority; taskParams.stackSize = 4*1024; gCLI.cliTaskHandle = Task_create(CLI_task, &taskParams, NULL); return 0; } /** * @b Description * @n * This is the function which is used to close the CLI module * * \ingroup CLI_UTIL_EXTERNAL_FUNCTION * * @retval * Success - 0 * @retval * Error - <0 */ int32_t CLI_close (void) { /* Shutdown the CLI Task */ Task_delete(&gCLI.cliTaskHandle); /* Cleanup the memory */ memset ((void*)&gCLI, 0, sizeof(CLI_MCB)); return 0; }
/* * @file cli.c * * @brief * CLI Utility implementation * * \par * NOTE: * (C) Copyright 2016 Texas Instruments, Inc. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /************************************************************************** *************************** Include Files ******************************** **************************************************************************/ /* Standard Include Files. */ #include <stdint.h> #include <stdlib.h> #include <stddef.h> #include <string.h> #include <stdio.h> /* BIOS/XDC Include Files. */ #include <xdc/std.h> #include <ti/sysbios/knl/Task.h> /* mmWave SDK Include Files: */ #include <ti/common/sys_common.h> #include <ti/drivers/uart/UART.h> #include <ti/utils/cli/cli.h> #include <ti/utils/cli/include/cli_internal.h> /************************************************************************** *************************** Global Variables ***************************** **************************************************************************/ /** * @brief Global variable which tracks the CLI MCB */ CLI_MCB gCLI; const char *defaultConfigCommands[] = { "sensorStop", "flushCfg", "dfeDataOutputMode 1", "channelCfg 15 7 0", "adcCfg 2 1", "adcbufCfg 0 1 0 1", "profileCfg 0 77 267 7 57.14 0 0 70 1 240 4884 0 0 30", "chirpCfg 0 0 0 0 0 0 0 1", "chirpCfg 1 1 0 0 0 0 0 4", "chirpCfg 2 2 0 0 0 0 0 2", "frameCfg 0 2 16 0 100 1 0", "lowPower 0 0", "guiMonitor 1 1 0 0 0 1", "cfarCfg 0 2 8 4 3 0 1280", "peakGrouping 1 1 1 1 229", "multiObjBeamForming 1 0.5", "clutterRemoval 1", "calibDcRangeSig 0 -5 8 256", "compRangeBiasAndRxChanPhase 0.0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0", "measureRangeBiasAndRxChanPhase 0 1.5 0.2", "CQRxSatMonitor 0 3 5 123 0", "CQSigImgMonitor 0 119 4", "analogMonitor 1 1", "sensorStart" }; /************************************************************************** **************************** CLI Functions ******************************* **************************************************************************/ /** * @b Description * @n * The function is the HELP generated by the CLI Module * * \ingroup CLI_UTIL_INTERNAL_FUNCTION * * @retval * Not Applicable. */ static int32_t CLI_help (int32_t argc, char* argv[]) { uint32_t index; /* Display the banner: */ CLI_write ("Help: This will display the usage of the CLI commands\n"); CLI_write ("Command: Help Description\n"); /* Cycle through all the registered CLI commands: */ for (index = 0; index < gCLI.numCLICommands; index++) { /* Display the help string*/ CLI_write ("%s: %s\n", gCLI.cfg.tableEntry[index].cmd, (gCLI.cfg.tableEntry[index].helpString == NULL) ? "No help available" : gCLI.cfg.tableEntry[index].helpString); } /* Is the mmWave Extension enabled? */ if (gCLI.cfg.enableMMWaveExtension == 1U) { /* YES: Pass the control to the extension help handler. */ CLI_MMWaveExtensionHelp (); } return 0; } /** * @b Description * @n * This is the CLI Execution Task * * \ingroup CLI_UTIL_INTERNAL_FUNCTION * * @retval * Not Applicable. */ static void CLI_task(UArg arg0, UArg arg1) { uint8_t cmdString[256]; char* tokenizedArgs[CLI_MAX_ARGS]; char* ptrCLICommand; char delimitter[] = " \r\n"; uint32_t argIndex; CLI_CmdTableEntry* ptrCLICommandEntry; int32_t cliStatus; uint32_t index; uint32_t cmdcnt = 0U; /* Do we have a banner to be displayed? */ if (gCLI.cfg.cliBanner != NULL) { /* YES: Display the banner */ CLI_write (gCLI.cfg.cliBanner); } /* Loop around forever: */ while (cmdcnt < 25) { /* Demo Prompt: */ CLI_write (gCLI.cfg.cliPrompt); /* Reset the command string: */ memset ((void *)&cmdString[0], 0, sizeof(cmdString)); /* Read the command message from the UART: */ UART_read (gCLI.cfg.cliUartHandle, &cmdString[0], (sizeof(cmdString) - 1)); /* Reset all the tokenized arguments: */ memset ((void *)&tokenizedArgs, 0, sizeof(tokenizedArgs)); argIndex = 0; // ptrCLICommand = (char*)&cmdString[0]; ptrCLICommand = (char*)defaultConfigCommands[cmdcnt]; cmdcnt++; /* comment lines found - ignore the whole line*/ if (cmdString[0]=='%') { CLI_write ("Skipped\n"); continue; } /* Set the CLI status: */ cliStatus = -1; /* The command has been entered we now tokenize the command message */ while (1) { /* Tokenize the arguments: */ tokenizedArgs[argIndex] = strtok(ptrCLICommand, delimitter); if (tokenizedArgs[argIndex] == NULL) break; /* Increment the argument index: */ argIndex++; if (argIndex >= CLI_MAX_ARGS) break; /* Reset the command string */ ptrCLICommand = NULL; } /* Were we able to tokenize the CLI command? */ if (argIndex == 0) continue; /* Cycle through all the registered CLI commands: */ for (index = 0; index < gCLI.numCLICommands; index++) { ptrCLICommandEntry = &gCLI.cfg.tableEntry[index]; /* Do we have a match? */ if (strcmp(ptrCLICommandEntry->cmd, tokenizedArgs[0]) == 0) { /* YES: Pass this to the CLI registered function */ cliStatus = ptrCLICommandEntry->cmdHandlerFxn (argIndex, tokenizedArgs); if (cliStatus == 0) { CLI_write ("Done\n"); } else { CLI_write ("Error %d\n", cliStatus); } break; } } /* Did we get a matching CLI command? */ if (index == gCLI.numCLICommands) { /* NO matching command found. Is the mmWave extension enabled? */ if (gCLI.cfg.enableMMWaveExtension == 1U) { /* Yes: Pass this to the mmWave extension handler */ cliStatus = CLI_MMWaveExtensionHandler (argIndex, tokenizedArgs); } /* Was the CLI command found? */ if (cliStatus == -1) { /* No: The command was still not found */ CLI_write ("'%s' is not recognized as a CLI command\n", tokenizedArgs[0]); } } } } /** * @b Description * @n * Logging function which can log the messages to the CLI console * * @param[in] format * Format string * * \ingroup CLI_UTIL_EXTERNAL_FUNCTION * * @retval * Not Applicable. */ void CLI_write (const char* format, ...) { va_list arg; char logMessage[256]; int32_t sizeMessage; /* Format the message: */ va_start (arg, format); sizeMessage = vsnprintf (&logMessage[0], sizeof(logMessage), format, arg); va_end (arg); /* Log the message on the UART CLI console: */ if (gCLI.cfg.usePolledMode == true) { /* Polled mode: */ UART_writePolling (gCLI.cfg.cliUartHandle, (uint8_t*)&logMessage[0], sizeMessage); } else { /* Blocking Mode: */ UART_write (gCLI.cfg.cliUartHandle, (uint8_t*)&logMessage[0], sizeMessage); } } /** * @b Description * @n * This is the function which is used to initialize and setup the CLI * * @param[in] ptrCLICfg * Pointer to the CLI configuration * * \ingroup CLI_UTIL_EXTERNAL_FUNCTION * * @retval * Success - 0 * @retval * Error - <0 */ int32_t CLI_open (CLI_Cfg* ptrCLICfg) { Task_Params taskParams; uint32_t index; /* Sanity Check: Validate the arguments */ if (ptrCLICfg == NULL) return -1; /* Initialize the CLI MCB: */ memset ((void*)&gCLI, 0, sizeof(CLI_MCB)); /* Copy over the configuration: */ memcpy ((void *)&gCLI.cfg, (void *)ptrCLICfg, sizeof(CLI_Cfg)); /* Cycle through and determine the number of supported CLI commands: */ for (index = 0; index < CLI_MAX_CMD; index++) { /* Do we have a valid entry? */ if (gCLI.cfg.tableEntry[index].cmd == NULL) { /* NO: This is the last entry */ break; } else { /* YES: Increment the number of CLI commands */ gCLI.numCLICommands = gCLI.numCLICommands + 1; } } /* Is the mmWave Extension enabled? */ if (gCLI.cfg.enableMMWaveExtension == 1U) { /* YES: Initialize the CLI Extension: */ if (CLI_MMWaveExtensionInit (ptrCLICfg) < 0) return -1; } /* Do we have a CLI Prompt specified? */ if (gCLI.cfg.cliPrompt == NULL) gCLI.cfg.cliPrompt = "CLI:/>"; /* The CLI provides a help command by default: * - Since we are adding this at the end of the table; a user of this module can also * override this to provide its own implementation. */ gCLI.cfg.tableEntry[gCLI.numCLICommands].cmd = "help"; gCLI.cfg.tableEntry[gCLI.numCLICommands].helpString = NULL; gCLI.cfg.tableEntry[gCLI.numCLICommands].cmdHandlerFxn = CLI_help; /* Increment the number of CLI commands: */ gCLI.numCLICommands++; /* Initialize the task parameters and launch the CLI Task: */ Task_Params_init(&taskParams); taskParams.priority = gCLI.cfg.taskPriority; taskParams.stackSize = 4*1024; gCLI.cliTaskHandle = Task_create(CLI_task, &taskParams, NULL); return 0; } /** * @b Description * @n * This is the function which is used to close the CLI module * * \ingroup CLI_UTIL_EXTERNAL_FUNCTION * * @retval * Success - 0 * @retval * Error - <0 */ int32_t CLI_close (void) { /* Shutdown the CLI Task */ Task_delete(&gCLI.cliTaskHandle); /* Cleanup the memory */ memset ((void*)&gCLI, 0, sizeof(CLI_MCB)); return 0; }
