Hello Team,
May I know if there is power sequence for TMP112 V+ and SDA/SCL? If I power up the I2C bus voltage first, SDA/SCL power up first, and then power up V+, will there be any temperature reading problem? If there is power sequence, what is the minimum delay time for SDA/SCL to V+ supply voltage?
Thank you.
