CCS/AWR1642BOOST: Getting the temperature data from AWR1642
Part Number: AWR1642BOOST
Other Parts Discussed in Thread: AWR1642
Dear support team
I found that AWR1642 has a temperature sensor.
Could you tell me how to get the temperature form the temperature sensor and provide a demo about this?
Roger
  • Hi Roger,
    You can use 'rlRfGetTemperatureReport' API of mmWaveLink (rl_sensor.c) to get the device temperature where received data will be in the format of a rlRfTempData structure.
    You can integrate this API in the mmWaveLink test application.
    Note- You will the difference in temperature data only if the device heats up by 10 degrees. And try to invoke this API at a 1-second interval to get the effective output result.
    Jitendra
