HDC2080: window dimension and ambient temperature around HDC2080
Part Number: HDC2080
Dear team,
I saw our application note" Optimizing Placement and Routing for Humidity Sensors" said that
1. A design with air flow around the sensor is favorable in terms of response times and Figure 3 to Figure 9 list recommended component placement. May I know do we have any suggestion values about minimum dimension of windows?
2. Temperature changes cause relative humidity changes, so isolating the sensor from the heat source is important. Customer want to know do we have any recommendation values of ambient temperature around HDC2080 that can not exceed? Thank you.
Polly Chung
