Part Number: HDC1080
one of my client is currently using HDC1080 sensor on their test to read out humidity in a closed environment. During design tape out, pin-7 was left floating as per datasheet guideline whereas pin-7 was connected to GND on the EVM. Will this affect the accuracy of sensor in reading RH levels?
the issue that showed up was the accuracy of %RH reading; upon inspection the HDC1080 on customer board is labeled as 741R & reading differed up to 15%RH vs EVM. Next we performed AB swap on humidity sensor (carrying datecode of 821R) & the outcome tallies with what we're reading on EVM. Are there any calibration required which we may have missed out that may caused the issue mentioned? Please advise.
Leo
