CCS/IWR1642BOOST: unable to run modified source code in debug mode
Part Number: IWR1642BOOST
I am trying to run SDK 2.0.0.4 out of box demo in debug mode with hard coded config values.
For this purpose I follwed "MMWAVE SDK User Guide" section "3. 2. 1. Demonstration Mode".
But when I run the mss and dss respectively I get following error.
[Cortex_R4_0] **********************************************
Debug: Launching the Millimeter Wave Demo
Debug: MMWDemoMSS Launched the Initialization Task
Debug: MMWDemoMSS mmWave Control Initialization was successful
[C674X_0] Debug: MMWDemoDSS mmWave Control Initialization succeeded
[Cortex_R4_0] Debug: CLI is operational
Exception occurred in ThreadType_Task.
Task handle: 0x80002c0.
Task stack base: 0x20202020.
Task stack size: 0x20202020.
R0 = 0xffffffff R8 = 0x0000000f
R1 = 0x17280200 R9 = 0x00017f84
R2 = 0x000c011f R10 = 0x00000000
R3 = 0x06f00010 R11 = 0x00000064
R4 = 0x0800cf10 R12 = 0x00000000
R5 = 0x080002c0 SP(R13) = 0x080004d8
R6 = 0x20202020 LR(R14) = 0x00003d6c
R7 = 0x080002d3 PC(R15) = 0x0000b8e4
PSR = 0x600c019f
DFSR = 0x00000801 IFSR = 0x00000000
DFAR = 0xffffffff IFAR = 0x00000000
ti.sysbios.family.arm.exc.Exception: line 205: E_dataAbort: pc = 0x0000b8e4, lr = 0x00003d6c.
xdc.runtime.Error.raise: terminating execution
I am also attaching the file cli.c with modifications for hard coded values.
Thanks in advance
Vikas
 *   @file  cli.c
 *   @brief
 *      Mmw (Milli-meter wave) DEMO CLI Implementation
 *  \par
 *  NOTE:
 *      (C) Copyright 2016 Texas Instruments, Inc.
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *************************** Include Files ********************************
/* Standard Include Files. */
#include <stdint.h>
#include <stdlib.h>
#include <stddef.h>
#include <string.h>
#include <stdio.h>
/* BIOS/XDC Include Files. */
#include <xdc/std.h>
#include <xdc/cfg/global.h>
#include <xdc/runtime/IHeap.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/Memory.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Event.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/heaps/HeapBuf.h>
#include <ti/sysbios/heaps/HeapMem.h>
/* mmWave SDK Include Files: */
#include <ti/common/sys_common.h>
#include <ti/common/mmwave_sdk_version.h>
#include <ti/drivers/uart/UART.h>
#include <ti/control/mmwavelink/mmwavelink.h>
#include <ti/utils/cli/cli.h>
#include <ti/utils/cli/include/cli_internal.h>
/* Demo Include Files */
#include "ti/demo/xwr16xx/mmw/mss/mss_mmw.h"
#include "ti/demo/xwr16xx/mmw/common/mmw_messages.h"
 *************************** Hard-coded Configuation **********************
#define USE_HARD_CODED_CONFIG
#ifdef USE_HARD_CODED_CONFIG
int32_t hardCodedConfigIndex;
char * hardCodedConfigCommands[] =
"% Created for SDK ver:02.00",
"% Created using Visualizer ver:2.0.0.2",
"% Frequency:77",
"% Platform:xWR16xx",
"% Scene Classifier:best_range_res",
"% Azimuth Resolution(deg):15",
"% Range Resolution(m):0.044",
"% Maximum unambiguous Range(m):9.02",
"% Maximum Radial Velocity(m/s):1",
"% Radial velocity resolution(m/s):0.13",
"% Frame Duration(msec):100",
"% Range Detection Threshold (dB):15",
"% Doppler Detection Threshold (dB):15",
"% Range Peak Grouping:enabled",
"% Doppler Peak Grouping:enabled",
"% Static clutter removal:disabled",
"sensorStop",
"flushCfg",
"dfeDataOutputMode 1",
"channelCfg 15 3 0",
"adcCfg 2 1",
"adcbufCfg -1 0 0 1 0",
"profileCfg 0 77 7 7 58 0 0  68 1 256 5500 0 0 30",
"chirpCfg 0 0 0 0 0 0 0 3",
"chirpCfg 1 1 0 0 0 0 0 3",
"bpmCfg -1 1 0 1",
"frameCfg 0 1 32 0 200 1 0",
"lowPower 0 1",
"guiMonitor -1 1 1 1 1 0 1",
"cfarCfg -1 0 2 8 4 4 0 5120",
"cfarCfg -1 1 0 8 4 4 0 5120",
"peakGrouping -1 1 0 0 1 224",
"multiObjBeamForming -1 1 0.5",
"calibDcRangeSig -1 0 -5 8 256",
"extendedMaxVelocity -1 0",
"clutterRemoval -1 0",
"compRangeBiasAndRxChanPhase 0.0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0",
"measureRangeBiasAndRxChanPhase 0 1.5 0.2",
"nearFieldCfg -1 0 0 0",
"CQRxSatMonitor 0 3 4 127 0",
"CQSigImgMonitor 0 63 8",
"analogMonitor 1 1",
"lvdsStreamCfg -1 0 0 0",
"sensorStart",
"!!!END_OF_HARD_CODED_COMMANDS",
#endif
CLI_MCB     gCli;
 *************************** Local Definitions ****************************
/* CLI Extended Command Functions */
static int32_t MmwDemo_CLICfarCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIPeakGroupingCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIMultiObjBeamForming (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLICalibDcRangeSig (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIExtendedMaxVelocity (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIClutterRemoval (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLISensorStart (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLISensorStop (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIGuiMonSel (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLISetDataLogger (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIADCBufCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLICompRangeBiasAndRxChanPhaseCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIMeasureRangeBiasAndRxChanPhaseCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLINearFieldCorrection (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIChirpQualityRxSatMonCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIChirpQualitySigImgMonCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIAnalogMonitorCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLILvdsStreamCfg (int32_t argc, char* argv[]);
 *************************** Extern Definitions *******************************
extern MmwDemo_MCB    gMmwMssMCB;
extern int32_t MmwDemo_mboxWrite(MmwDemo_message     * message);
 *************************** CLI  Function Definitions **************************
 *  @b Description
 *  @n
 *      This is the CLI Handler for the sensor start command
 *  @param[in] argc
 *      Number of arguments
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    bool doReconfig = true;
    if (argc==2)
        doReconfig = (bool) atoi (argv[1]);
    /* Post sensorSTart event to notify configuration is done */
    MmwDemo_notifySensorStart(doReconfig);
    /* Pend for completion */
    return (MmwDemo_waitSensorStartComplete());
 *  @b Description
 *  @n
 *      This is the CLI Handler for the sensor stop command
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    /* Post sensorSTOP event to notify sensor stop command */
    MmwDemo_notifySensorStop();
    MmwDemo_waitSensorStopComplete();
    return 0;
static int32_t MmwDemo_CLIGetSubframe (int32_t argc, char* argv[], int32_t expectedArgc, int8_t* subFrameNum)
    int8_t subframe;
    /* Sanity Check: Minimum argument check */
    if (argc != expectedArgc)
        CLI_write ("Error: Invalid usage of the CLI command\n");
        return -1;
    /*Subframe info is always in position 1*/
    subframe = (int8_t) atoi(argv[1]);
    if(subframe >= (int8_t)RL_MAX_SUBFRAMES)
        CLI_write ("Error: Subframe number is invalid\n");
        return -1;
    *subFrameNum = (int8_t)subframe;
    return 0;
static void MmwDemo_mssCfgUpdate(void *srcPtr, uint32_t offset, uint32_t size, int8_t subFrameNum)
    /* if subFrameNum undefined, broadcast to all sub-frames */
    if(subFrameNum == MMWDEMO_SUBFRAME_NUM_FRAME_LEVEL_CONFIG)
        uint8_t  indx;
        for(indx = 0; indx < RL_MAX_SUBFRAMES; indx++)
            memcpy((void *)((uint32_t) &gMmwMssMCB.cliCfg[indx] + offset), srcPtr, size);
    else
        /* Apply configuration to specific subframe (or to position zero for the legacy case
           where there is no advanced frame config) */
        memcpy((void *)((uint32_t) &gMmwMssMCB.cliCfg[subFrameNum] + offset), srcPtr, size);
 *  @b Description
 *  @n
 *      This is the CLI Handler for gui monitoring configuration
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_GuiMonSel   guiMonSel;
    MmwDemo_message     message;
    int8_t              subFrameNum;
    if(MmwDemo_CLIGetSubframe(argc, argv, 8, &subFrameNum) < 0)
        return -1;
    /* Initialize the guiMonSel configuration: */
    memset ((void *)&guiMonSel, 0, sizeof(MmwDemo_GuiMonSel));
    /* Populate configuration: */
    guiMonSel.detectedObjects           = atoi (argv[2]);
    guiMonSel.logMagRange               = atoi (argv[3]);
    guiMonSel.noiseProfile              = atoi (argv[4]);
    guiMonSel.rangeAzimuthHeatMap       = atoi (argv[5]);
    guiMonSel.rangeDopplerHeatMap       = atoi (argv[6]);
    guiMonSel.statsInfo                 = atoi (argv[7]);
    MmwDemo_mssCfgUpdate((void *)&guiMonSel, offsetof(MmwDemo_CliCfg_t, guiMonSel),
        sizeof(MmwDemo_GuiMonSel), subFrameNum);
    /* Send configuration to DSS */
    memset((void *)&message, 0, sizeof(MmwDemo_message));
    message.type = MMWDEMO_MSS2DSS_GUIMON_CFG;
    message.subFrameNum = subFrameNum;
    memcpy((void *)&message.body.guiMonSel, (void *)&guiMonSel, sizeof(MmwDemo_GuiMonSel));
    if (MmwDemo_mboxWrite(&message) == 0)
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for CFAR configuration
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_CfarCfg     cfarCfg;
    uint32_t            procDirection;
    int8_t              subFrameNum;
    if(MmwDemo_CLIGetSubframe(argc, argv, 9, &subFrameNum) < 0)
        return -1;
    /* Initialize configuration: */
    memset ((void *)&cfarCfg, 0, sizeof(MmwDemo_CfarCfg));
    procDirection             = (uint32_t) atoi (argv[2]);
    cfarCfg.averageMode       = (uint8_t) atoi (argv[3]);
    cfarCfg.winLen            = (uint8_t) atoi (argv[4]);
    cfarCfg.guardLen          = (uint8_t) atoi (argv[5]);
    cfarCfg.noiseDivShift     = (uint8_t) atoi (argv[6]);
    cfarCfg.cyclicMode        = (uint8_t) atoi (argv[7]);
    cfarCfg.thresholdScale    = (uint16_t) atoi (argv[8]);
    /* Save Configuration to use later */
    if (procDirection == 0)
        MmwDemo_mssCfgUpdate((void *)&cfarCfg, offsetof(MmwDemo_CliCfg_t, cfarCfgRange),
            sizeof(MmwDemo_CfarCfg), subFrameNum);
    else
        MmwDemo_mssCfgUpdate((void *)&cfarCfg, offsetof(MmwDemo_CliCfg_t, cfarCfgDoppler),
        message.type = MMWDEMO_MSS2DSS_CFAR_RANGE_CFG;
    else if (procDirection == 1)
        message.type = MMWDEMO_MSS2DSS_CFAR_DOPPLER_CFG;
    else
        return -1;
    memcpy((void *)&message.body.cfarCfg, (void *)&cfarCfg, sizeof(MmwDemo_CfarCfg));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for Peak grouping configuration
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_PeakGroupingCfg peakGroupingCfg;
    int8_t                  subFrameNum;
    if(MmwDemo_CLIGetSubframe(argc, argv, 7, &subFrameNum) < 0)
        return -1;
    memset ((void *)&peakGroupingCfg, 0, sizeof(MmwDemo_PeakGroupingCfg));
    peakGroupingCfg.scheme               = (uint8_t) atoi (argv[2]);
    peakGroupingCfg.inRangeDirectionEn   = (uint8_t) atoi (argv[3]);
    peakGroupingCfg.inDopplerDirectionEn = (uint8_t) atoi (argv[4]);
    peakGroupingCfg.minRangeIndex    = (uint16_t) atoi (argv[5]);
    peakGroupingCfg.maxRangeIndex    = (uint16_t) atoi (argv[6]);
    if (peakGroupingCfg.scheme != 1 && peakGroupingCfg.scheme != 2)
        CLI_write ("Error: Invalid peak grouping scheme\n");
        return -1;
    MmwDemo_mssCfgUpdate((void *)&peakGroupingCfg, offsetof(MmwDemo_CliCfg_t, peakGroupingCfg),
        sizeof(MmwDemo_PeakGroupingCfg), subFrameNum);
    message.type = MMWDEMO_MSS2DSS_PEAK_GROUPING_CFG;
    memcpy((void *)&message.body.peakGroupingCfg, (void *)&peakGroupingCfg, sizeof(MmwDemo_PeakGroupingCfg));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for multi object beam forming configuration
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_MultiObjBeamFormingCfg cfg;
    int8_t              subFrameNum;
    if(MmwDemo_CLIGetSubframe(argc, argv, 4, &subFrameNum) < 0)
        return -1;
    memset ((void *)&cfg, 0, sizeof(MmwDemo_MultiObjBeamFormingCfg));
    cfg.enabled                     = (uint8_t) atoi (argv[2]);
    cfg.multiPeakThrsScal           = (float) atof (argv[3]);
    MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, multiObjBeamFormingCfg),
        sizeof(MmwDemo_MultiObjBeamFormingCfg), subFrameNum);
    message.type = MMWDEMO_MSS2DSS_MULTI_OBJ_BEAM_FORM;
    memcpy((void *)&message.body.multiObjBeamFormingCfg, (void *)&cfg, sizeof(MmwDemo_MultiObjBeamFormingCfg));
        return 0;
    else
        return -1;
uint32_t log2Approx(uint32_t x)
    uint32_t idx, detectFlag = 0;
    if ( x < 2)
        return (0);
    idx = 32U;
    while((detectFlag==0U) || (idx==0U))
        if(x & 0x80000000U)
            detectFlag = 1;
        x <<= 1U;
        idx--;
    if(x != 0)
        idx = idx + 1;
    return(idx);
 *  @b Description
 *  @n
 *      This is the CLI Handler for DC range calibration
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_CalibDcRangeSigCfg cfg;
    uint32_t                   log2NumAvgChirps;
    int8_t                     subFrameNum;
    if(MmwDemo_CLIGetSubframe(argc, argv, 6, &subFrameNum) < 0)
        return -1;
    /* Initialize configuration for DC range signature calibration */
    memset ((void *)&cfg, 0, sizeof(MmwDemo_CalibDcRangeSigCfg));
    cfg.enabled          = (uint16_t) atoi (argv[2]);
    cfg.negativeBinIdx   = (int16_t)  atoi (argv[3]);
    cfg.positiveBinIdx   = (int16_t)  atoi (argv[4]);
    cfg.numAvgChirps     = (uint16_t)  atoi (argv[5]);
    if (cfg.negativeBinIdx > 0)
        CLI_write ("Error: Invalid negative bin index\n");
        return -1;
    if ((cfg.positiveBinIdx - cfg.negativeBinIdx + 1) > DC_RANGE_SIGNATURE_COMP_MAX_BIN_SIZE)
        CLI_write ("Error: Number of bins exceeds the limit\n");
        return -1;
    log2NumAvgChirps = (uint32_t) log2Approx (cfg.numAvgChirps);
    if (cfg.numAvgChirps != (1 << log2NumAvgChirps))
        CLI_write ("Error: Number of averaged chirps is not power of two\n");
        return -1;
    MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, calibDcRangeSigCfg),
        sizeof(MmwDemo_CalibDcRangeSigCfg), subFrameNum);
    message.type = MMWDEMO_MSS2DSS_CALIB_DC_RANGE_SIG;
    memcpy((void *)&message.body.calibDcRangeSigCfg, (void *)&cfg, sizeof(MmwDemo_CalibDcRangeSigCfg));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for Velocity Disambiguation Configuration
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_ExtendedMaxVelocityCfg cfg;
    int8_t                         subFrameNum;
    if(MmwDemo_CLIGetSubframe(argc, argv, 3, &subFrameNum) < 0)
        return -1;
    memset ((void *)&cfg, 0, sizeof(MmwDemo_ExtendedMaxVelocityCfg));
    MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, extendedMaxVelocityCfg),
        sizeof(MmwDemo_ExtendedMaxVelocityCfg), subFrameNum);
    message.type = MMWDEMO_MSS2DSS_EXTENDED_MAX_VELOCITY;
    memcpy((void *)&message.body.extendedMaxVelocityCfg, (void *)&cfg, sizeof(MmwDemo_ExtendedMaxVelocityCfg));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for Near field correction Configuration
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_NearFieldCorrectionCfg cfg;
    int8_t                         subFrameNum;
    if(MmwDemo_CLIGetSubframe(argc, argv, 5, &subFrameNum) < 0)
        return -1;
    /* Initialize configuration for Near Field Correction */
    memset ((void *)&cfg, 0, sizeof(MmwDemo_NearFieldCorrectionCfg));
    cfg.enabled       = (uint8_t) atoi(argv[2]);
    cfg.startRangeIdx = (uint16_t) atoi(argv[3]);
    cfg.endRangeIdx   = (uint16_t) atoi(argv[4]);
    MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, nearFieldCorrectionCfg),
        sizeof(MmwDemo_NearFieldCorrectionCfg), subFrameNum);
    message.type = MMWDEMO_MSS2DSS_NEAR_FIELD_CFG;
    memcpy((void *)&message.body.nearFieldCorrectionCfg, (void *)&cfg,
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      Clutter removal Configuration
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_ClutterRemovalCfg cfg;
    int8_t              subFrameNum;
        return -1;
    /* Initialize configuration for clutter removal */
    memset ((void *)&cfg, 0, sizeof(MmwDemo_ClutterRemovalCfg));
    MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, clutterRemovalCfg),
        sizeof(MmwDemo_ClutterRemovalCfg), subFrameNum);
    message.type = MMWDEMO_MSS2DSS_CLUTTER_REMOVAL;
    memcpy((void *)&message.body.clutterRemovalCfg, (void *)&cfg, sizeof(MmwDemo_ClutterRemovalCfg));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for data logger set command
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    if (argc != 2)
        return -1;
    if (strcmp(argv[1], "mssLogger") == 0)
        gMmwMssMCB.cfg.dataLogger = 0;
    else if (strcmp(argv[1], "dssLogger") == 0)
        gMmwMssMCB.cfg.dataLogger = 1;
    else
        return -1;
    message.type = MMWDEMO_MSS2DSS_SET_DATALOGGER;
    message.body.dataLogger = gMmwMssMCB.cfg.dataLogger;
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_ADCBufCfg   adcBufCfg;
    int8_t              subFrameNum;
        return -1;
    /* Initialize the ADC Output configuration: */
    memset ((void *)&adcBufCfg, 0, sizeof(MmwDemo_ADCBufCfg));
    adcBufCfg.adcFmt          = (uint8_t) atoi (argv[2]);
    adcBufCfg.iqSwapSel       = (uint8_t) atoi (argv[3]);
    adcBufCfg.chInterleave    = (uint8_t) atoi (argv[4]);
    adcBufCfg.chirpThreshold  = (uint8_t) atoi (argv[5]);
    MmwDemo_mssCfgUpdate((void *)&adcBufCfg, offsetof(MmwDemo_CliCfg_t, adcBufCfg),
        sizeof(MmwDemo_ADCBufCfg), subFrameNum);
    message.type = MMWDEMO_MSS2DSS_ADCBUFCFG;
    memcpy((void *)&message.body.adcBufCfg, (void *)&adcBufCfg, sizeof(MmwDemo_ADCBufCfg));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for compensation of range bias and channel phase offsets
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_compRxChannelBiasCfg_t   cfg;
    int32_t Re, Im;
    int32_t argInd;
    int32_t i;
    if (argc != (1+1+SYS_COMMON_NUM_TX_ANTENNAS*SYS_COMMON_NUM_RX_CHANNEL*2))
        return -1;
    memset ((void *)&cfg, 0, sizeof(MmwDemo_compRxChannelBiasCfg_t));
    cfg.rangeBias          = (float) atof (argv[1]);
    argInd = 2;
    for (i=0; i < SYS_COMMON_NUM_TX_ANTENNAS*SYS_COMMON_NUM_RX_CHANNEL; i++)
        Re = (int32_t) (atof (argv[argInd++]) * 32768.);
        Re = MMWDEMO_SATURATE_HIGH(Re);
        Re = MMWDEMO_SATURATE_LOW(Re);
        cfg.rxChPhaseComp[i].real = (int16_t) Re;
        Im = (int32_t) (atof (argv[argInd++]) * 32768.);
        Im = MMWDEMO_SATURATE_HIGH(Im);
        Im = MMWDEMO_SATURATE_LOW(Im);
        cfg.rxChPhaseComp[i].imag = (int16_t) Im;
    memcpy((void *) &gMmwMssMCB.cliCommonCfg.compRxChanCfg, &cfg, sizeof(MmwDemo_compRxChannelBiasCfg_t));
    message.type = MMWDEMO_MSS2DSS_COMP_RANGE_BIAS_AND_RX_CHAN_PHASE;
    memcpy((void *)&message.body.compRxChanCfg, (void *)&cfg, sizeof(MmwDemo_compRxChannelBiasCfg_t));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for measurement configuration of range bias
 *      and channel phase offsets
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    MmwDemo_measureRxChannelBiasCfg_t   cfg;
    if (argc != 4)
        return -1;
    memset ((void *)&cfg, 0, sizeof(MmwDemo_measureRxChannelBiasCfg_t));
    cfg.enabled          = (uint8_t) atoi (argv[1]);
    cfg.targetDistance   = (float) atof (argv[2]);
    cfg.searchWinSize   = (float) atof (argv[3]);
    memcpy((void *) &gMmwMssMCB.cliCommonCfg.measureRxChanCfg, &cfg, sizeof(MmwDemo_measureRxChannelBiasCfg_t));
    message.type = MMWDEMO_MSS2DSS_MEASURE_RANGE_BIAS_AND_RX_CHAN_PHASE;
    memcpy((void *)&message.body.measureRxChanCfg, (void *)&cfg, sizeof(MmwDemo_measureRxChannelBiasCfg_t));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for BPM configuration supported by the mmw Demo
 *      Note that there is a generic BPM configuration command supported by
 *      utils/cli and mmwave. The generic BPM command is not supported by the
 *      demo as the mmw demo assumes a specific BPM pattern for the TX antennas.
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
static int32_t MmwDemo_CLIBpmCfg (int32_t argc, char* argv[])
    int8_t           subFrameNum;
    MmwDemo_BpmCfg   cfg;
    if (argc != 5)
        return -1;
        return -1;
    memset ((void *)&cfg, 0, sizeof(MmwDemo_BpmCfg));
    cfg.isEnabled = (bool) atoi(argv[2]) ;
    cfg.chirp0Idx = (uint16_t) atoi(argv[3]) ;
    cfg.chirp1Idx = (uint16_t) atoi(argv[4]) ;
    MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, bpmCfg),
        sizeof(MmwDemo_BpmCfg), subFrameNum);
    message.type = MMWDEMO_MSS2DSS_BPM_CFG;
    memcpy((void *)&message.body.bpmCfg, (void *)&cfg, sizeof(MmwDemo_BpmCfg));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for configuring CQ RX Saturation monitor
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    rlRxSatMonConf_t        cqSatMonCfg;
    if (argc != 6)
        return -1;
    memset ((void *)&cqSatMonCfg, 0, sizeof(rlRxSatMonConf_t));
    cqSatMonCfg.profileIndx                 = (uint8_t) atoi (argv[1]);
    if(cqSatMonCfg.profileIndx < RL_MAX_PROFILES_CNT)
        cqSatMonCfg.satMonSel                   = (uint8_t) atoi (argv[2]);
        cqSatMonCfg.primarySliceDuration        = (uint16_t) atoi (argv[3]);
        cqSatMonCfg.numSlices                   = (uint16_t) atoi (argv[4]);
        cqSatMonCfg.rxChannelMask               = (uint8_t) atoi (argv[5]);
        memcpy((void *) &gMmwMssMCB.cliCommonCfg.cqSatMonCfg[cqSatMonCfg.profileIndx],
                       &cqSatMonCfg,
        message.type = MMWDEMO_MSS2DSS_CQ_SATURATION_MONITOR;
        memcpy((void *)&message.body.cqSatMonCfg, (void *)&cqSatMonCfg, sizeof(rlRxSatMonConf_t));
            return 0;
        else
            return -1;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for configuring CQ Singal & Image band monitor
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    rlSigImgMonConf_t       cqSigImgMonCfg;
    if (argc != 4)
        return -1;
    memset ((void *)&cqSigImgMonCfg, 0, sizeof(rlSigImgMonConf_t));
    cqSigImgMonCfg.profileIndx              = (uint8_t) atoi (argv[1]);
    if(cqSigImgMonCfg.profileIndx < RL_MAX_PROFILES_CNT)
        cqSigImgMonCfg.numSlices            = (uint8_t) atoi (argv[2]);
        cqSigImgMonCfg.timeSliceNumSamples  = (uint16_t) atoi (argv[3]);
        memcpy((void *) &gMmwMssMCB.cliCommonCfg.cqSigImgMonCfg[cqSigImgMonCfg.profileIndx],
                &cqSigImgMonCfg,
        message.type = MMWDEMO_MSS2DSS_CQ_SIGIMG_MONITOR;
        memcpy((void *)&message.body.cqSigImgMonCfg, (void *)&cqSigImgMonCfg, sizeof(rlSigImgMonConf_t));
            return 0;
        else
            return -1;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for enabling analog monitors
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    if (argc != 3)
        return -1;
    gMmwMssMCB.cliCommonCfg.anaMonCfg.rxSatMonEn = atoi (argv[1]);
    gMmwMssMCB.cliCommonCfg.anaMonCfg.sigImgMonEn = atoi (argv[2]);
    message.type = MMWDEMO_MSS2DSS_ANALOG_MONITOR;
    memcpy((void *)&message.body.anaMonCfg,
            (void *)&gMmwMssMCB.cliCommonCfg.anaMonCfg,
            sizeof(MmwDemo_AnaMonitorCfg));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Handler for the High Speed Interface
 *  @param[in] argc
 *  @param[in] argv
 *      Arguments
 *  @retval
 *      Success -   0
 *  @retval
 *      Error   -   <0
    int8_t                  subFrameNum;
    MmwDemo_LvdsStreamCfg   cfg;
    if (argc != 5)
        return -1;
        return -1;
    memset ((void *)&cfg, 0, sizeof(MmwDemo_LvdsStreamCfg));
    cfg.isHeaderEnabled = (bool) atoi(argv[2]) ;
    cfg.dataFmt         = (uint8_t) atoi(argv[3]) ;
    cfg.isSwEnabled     = (bool) atoi(argv[4]) ;
    MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, lvdsStreamCfg),
        sizeof(MmwDemo_LvdsStreamCfg), subFrameNum);
    message.type = MMWDEMO_MSS2DSS_LVDSSTREAM_CFG;
    memcpy((void *)&message.body.lvdsStreamCfg, (void *)&cfg, sizeof(MmwDemo_LvdsStreamCfg));
        return 0;
    else
        return -1;
 *  @b Description
 *  @n
 *      This is the CLI Execution Task
 *  @retval
 *      Not Applicable.
void MmwDemo_CLIInit (void)
    CLI_Cfg     cliCfg;
    char        demoBanner[256];
    uint32_t    cnt;
    uint8_t                 cmdString[256];
    uint32_t                argIndex;
    char*                   tokenizedArgs[CLI_MAX_ARGS];
    char                    delimitter[] = " \r\n";
    uint32_t                index;
    char*                   ptrCLICommand;
    int32_t                 cliStatus;
    CLI_CmdTableEntry*      ptrCLICommandEntry;
    /* Create Demo Banner to be printed out by CLI */
    sprintf(&demoBanner[0],
                       "******************************************\n" \
                       "xWR16xx MMW Demo %02d.%02d.%02d.%02d\n"  \
                       "******************************************\n",
                        MMWAVE_SDK_VERSION_MAJOR,
                        MMWAVE_SDK_VERSION_MINOR,
                        MMWAVE_SDK_VERSION_BUGFIX,
                        MMWAVE_SDK_VERSION_BUILD
    /* Initialize the CLI configuration: */
    memset ((void *)&cliCfg, 0, sizeof(CLI_Cfg));
    /* Populate the CLI configuration: */
    cliCfg.cliPrompt                    = "mmwDemo:/>";
    cliCfg.cliBanner                    = demoBanner;
    cliCfg.cliUartHandle                = gMmwMssMCB.commandUartHandle;
    cliCfg.taskPriority                 = 3;
    cliCfg.mmWaveHandle                 = gMmwMssMCB.ctrlHandle;
    cliCfg.enableMMWaveExtension        = 1U;
    cliCfg.usePolledMode                = true;
    cnt=0;
    cliCfg.tableEntry[cnt].cmd            = "sensorStart";
    cliCfg.tableEntry[cnt].helpString     = "[doReconfig(optional, default:enabled)]";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLISensorStart;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "sensorStop";
    cliCfg.tableEntry[cnt].helpString     = "No arguments";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLISensorStop;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "guiMonitor";
    cliCfg.tableEntry[cnt].helpString     = "<subFrameIdx> <detectedObjects> <logMagRange> <noiseProfile> <rangeAzimuthHeatMap> <rangeDopplerHeatMap> <statsInfo>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIGuiMonSel;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "cfarCfg";
    cliCfg.tableEntry[cnt].helpString     = "<subFrameIdx> <procDirection> <averageMode> <winLen> <guardLen> <noiseDiv> <cyclicMode> <thresholdScale>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLICfarCfg;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "peakGrouping";
    cliCfg.tableEntry[cnt].helpString     = "<subFrameIdx> <groupingMode> <rangeDimEn> <dopplerDimEn> <startRangeIdx> <endRangeIdx>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIPeakGroupingCfg;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "dataLogger";
    cliCfg.tableEntry[cnt].helpString     = "<mssLogger | dssLogger>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLISetDataLogger;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "multiObjBeamForming";
    cliCfg.tableEntry[cnt].helpString     = "<subFrameIdx> <enabled> <threshold>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIMultiObjBeamForming;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "calibDcRangeSig";
    cliCfg.tableEntry[cnt].helpString     = "<subFrameIdx> <enabled> <negativeBinIdx> <positiveBinIdx> <numAvgFrames>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLICalibDcRangeSig;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "extendedMaxVelocity";
    cliCfg.tableEntry[cnt].helpString     = "<subFrameIdx> <enabled>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIExtendedMaxVelocity;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "clutterRemoval";
    cliCfg.tableEntry[cnt].helpString     = "<enabled>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIClutterRemoval;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "adcbufCfg";
    cliCfg.tableEntry[cnt].helpString     = "<subFrameIdx> <adcOutputFmt> <SampleSwap> <ChanInterleave> <ChirpThreshold>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIADCBufCfg;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "compRangeBiasAndRxChanPhase";
    cliCfg.tableEntry[cnt].helpString     = "<rangeBias> <Re00> <Im00> <Re01> <Im01> <Re02> <Im02> <Re03> <Im03> <Re10> <Im10> <Re11> <Im11> <Re12> <Im12> <Re13> <Im13> ";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLICompRangeBiasAndRxChanPhaseCfg;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "measureRangeBiasAndRxChanPhase";
    cliCfg.tableEntry[cnt].helpString     = "<enabled> <targetDistance> <searchWin>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIMeasureRangeBiasAndRxChanPhaseCfg;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "bpmCfg";
    cliCfg.tableEntry[cnt].helpString     = "<subFrameIdx> <enabled> <chirp0Idx> <chirp1Idx>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIBpmCfg;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "nearFieldCfg";
    cliCfg.tableEntry[cnt].helpString     = "<enabled> <startRangeIndex> <endRangeIndex>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLINearFieldCorrection;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "CQRxSatMonitor";
    cliCfg.tableEntry[cnt].helpString     = "<profile> <satMonSel> <priSliceDuration> <numSlices> <rxChanMask>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIChirpQualityRxSatMonCfg;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "CQSigImgMonitor";
    cliCfg.tableEntry[cnt].helpString     = "<profile> <numSlices> <numSamplePerSlice>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIChirpQualitySigImgMonCfg;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "analogMonitor";
    cliCfg.tableEntry[cnt].helpString     = "<rxSaturation> <sigImgBand>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLIAnalogMonitorCfg;
    cnt++;
    cliCfg.tableEntry[cnt].cmd            = "lvdsStreamCfg";
    cliCfg.tableEntry[cnt].helpString     = "<subFrameIdx> <enableHeader> <dataFmt> <enableSW>";
    cliCfg.tableEntry[cnt].cmdHandlerFxn  = MmwDemo_CLILvdsStreamCfg;
    cnt++;
    /* Open the CLI: */
    if (CLI_open (&cliCfg) < 0)
        System_printf ("Error: Unable to open the CLI\n");
        return;
    System_printf ("Debug: CLI is operational\n");
    hardCodedConfigIndex = 0;
    CLI_write ("Wait some time for system to initialize...\n");
    Task_sleep(100);
    /*unsigned long i=0;
    for(;i<1000000;i++);*/
    CLI_write ("Performing hard-coded config\n");
    while (1)
        /* Demo Prompt: */
        CLI_write (cliCfg.cliPrompt);
        /* Reset the command string: */
        memset ((void *)&cmdString[0], 0, sizeof(cmdString));
        /* Run hard-coded commands, one at a time until '!!!END_OF_HARD_CODED_COMMANDS' is reached: */
        if (hardCodedConfigCommands[hardCodedConfigIndex][0] != '!')
            //CLI_write (hardCodedConfigCommands[hardCodedConfigIndex]);
            CLI_write ("Command\n");
            memcpy((void *)&cmdString[0], (void *)hardCodedConfigCommands[hardCodedConfigIndex], strlen(hardCodedConfigCommands[hardCodedConfigIndex]));
            hardCodedConfigIndex++;
        /* Accept commands from UART after all hard-coded commands done: */
        else
            /* Read the command message from the UART: */
            UART_read (gCli.cfg.cliUartHandle, &cmdString[0], (sizeof(cmdString) - 1));
        /* Reset all the tokenized arguments: */
        memset ((void *)&tokenizedArgs, 0, sizeof(tokenizedArgs));
        argIndex      = 0;
        ptrCLICommand = (char*)&cmdString[0];
        /* comment lines found - ignore the whole line*/
        if (cmdString[0]=='%') {
            CLI_write ("Skipped\n");
            continue;
        /* Set the CLI status: */
        cliStatus = -1;
        /* The command has been entered we now tokenize the command message */
        while (1)
            /* Tokenize the arguments: */
            tokenizedArgs[argIndex] = strtok(ptrCLICommand, delimitter);
            if (tokenizedArgs[argIndex] == NULL)
                break;
            /* Increment the argument index: */
            argIndex++;
            if (argIndex >= CLI_MAX_ARGS)
                break;
            /* Reset the command string */
            ptrCLICommand = NULL;
        /* Were we able to tokenize the CLI command? */
        if (argIndex == 0)
            continue;
        /* Cycle through all the registered CLI commands: */
        //for (index = 0; index < gCli.numCLICommands; index++)
        for (index = 0; index < cnt; index++)
            ptrCLICommandEntry = &cliCfg.tableEntry[index];
            /* Do we have a match? */
            if (strcmp(ptrCLICommandEntry->cmd, tokenizedArgs[0]) == 0)
                /* YES: Pass this to the CLI registered function */
                cliStatus = ptrCLICommandEntry->cmdHandlerFxn (argIndex, tokenizedArgs);
                if (cliStatus == 0)
                    CLI_write ("Done\n");
                else
                    CLI_write ("Error %d\n", cliStatus);
                break;
        /* Did we get a matching CLI command? */
        if (index == cnt)
            /* NO matching command found. Is the mmWave extension enabled? */
            if (cliCfg.enableMMWaveExtension == 1U)
                /* Yes: Pass this to the mmWave extension handler */
                cliStatus = CLI_MMWaveExtensionHandler (argIndex, tokenizedArgs);
            /* Was the CLI command found? */
            if (cliStatus == -1)
                /* No: The command was still not found */
                CLI_write ("'%s' is not recognized as a CLI command\n", tokenizedArgs[0]);
#endif
    return;
  • Vikas,
    Looking at your code, I assume you are trying to follow the example provided in the following thread, for hardcoding the sensor configuration in cli.c
    https://e2e.ti.com/support/sensors/f/1023/p/708175/2616079#2616079
    However, it appears that you have modified the wrong file. Please note that as mentioned in the example above, you need to add this code to the cli.c that is part of the CLI library in the mmWave SDK and then need to re-compile the CLI library and then the demo code itself so that it can use the updated cli library. The file you need to modify per the example above is mmwave_sdk_02_00_00_04\packages\ti\utils\cli\src\cli.c.
    It appears that you've instead modified the cli.c which is part of the mmw demo i.e. mmwave_sdk_02_00_00_04\packages\ti\demo\xwr16xx\mmw\mss\cli.c.
    Please follow the instructions provided in the above referred example correctly and add the hardcoded configuration/code to the cli library code, then rebuild the cli library and finally the mmw demo itself to link with the updated library and retest.
    Please mark this thread if this resolves the problem otherwise get back if more support is needed.
    -Nitin
