Part Number: PGA460
Hi Akeem-san,
GUI have been updated, so the sample source which was shared from you couldn't be used.
Could you please give me the latest sample source again ?
Kato
Part Number: PGA460
Hi Akeem-san,
Kato
Hi Akeem-san,
Thank you for your quick response.
The GUI and the sample source are shown as below when BOOSTXL-PGA460 normally works with 300kHz transducer.
PGA460-Q1 EVM GUI
Device Firmware:
GUI Version: 1.0.1.4
2018-04-03
Public Release
;GRID_USER_MEMSPACE 00 (USER_DATA1),00 01 (USER_DATA2),00 02 (USER_DATA3),00 03 (USER_DATA4),00 04 (USER_DATA5),00 05 (USER_DATA6),00 06 (USER_DATA7),00 07 (USER_DATA8),00 08 (USER_DATA9),00 09 (USER_DATA10),00 0A (USER_DATA11),00 0B (USER_DATA12),00 0C (USER_DATA13),00 0D (USER_DATA14),00 0E (USER_DATA15),00 0F (USER_DATA16),00 10 (USER_DATA17),00 11 (USER_DATA18),00 12 (USER_DATA19),00 13 (USER_DATA20),00 14 (TVGAIN0),88 15 (TVGAIN1),88 16 (TVGAIN2),88 17 (TVGAIN3),00 18 (TVGAIN4),00 19 (TVGAIN5),00 1A (TVGAIN6),01 1B (INIT_GAIN),C0 1C (FREQUENCY),64 1D (DEADTIME),80 1E (PULSE_P1),06 1F (PULSE_P2),86 20 (CURR_LIM_P1),15 21 (CURR_LIM_P2),D5 22 (REC_LENGTH),03 23 (FREQ_DIAG),00 24 (SAT_FDIAG_TH),EE 25 (FVOLT_DEC),7C 26 (DECPL_TEMP),0F 27 (DSP_SCALE),00 28 (TEMP_TRIM),00 29 (P1_GAIN_CTRL),24 2A (P2_GAIN_CTRL),00 2B (EE_CRC),94 40 (EE_CNTRL),00 41 (BPF_A2_MSB),56 42 (BPF_A2_LSB),72 43 (BPF_A3_MSB),F3 44 (BPF_A3_LSB),72 45 (BPF_B1_MSB),06 46 (BPF_B1_LSB),47 47 (LPF_A2_MSB),7C 48 (LPF_A2_LSB),D3 49 (LPF_B1_MSB),01 4A (LPF_B1_LSB),97 4B (TEST_MUX),00 4C (DEV_STAT0),80 4D (DEV_STAT1),00 5F (P1_THR_0),88 60 (P1_THR_1),88 61 (P1_THR_2),88 62 (P1_THR_3),88 63 (P1_THR_4),88 64 (P1_THR_5),88 65 (P1_THR_6),84 66 (P1_THR_7),21 67 (P1_THR_8),08 68 (P1_THR_9),42 69 (P1_THR_10),10 6A (P1_THR_11),80 6B (P1_THR_12),80 6C (P1_THR_13),80 6D (P1_THR_14),80 6E (P1_THR_15),00 6F (P2_THR_0),88 70 (P2_THR_1),88 71 (P2_THR_2),88 72 (P2_THR_3),88 73 (P2_THR_4),88 74 (P2_THR_5),88 75 (P2_THR_6),84 76 (P2_THR_7),21 77 (P2_THR_8),08 78 (P2_THR_9),42 79 (P2_THR_10),10 7A (P2_THR_11),80 7B (P2_THR_12),80 7C (P2_THR_13),80 7D (P2_THR_14),80 7E (P2_THR_15),00 7F (THR_CRC),28 EOF
However, the register configuration cannot be completed with above sample source when using GUI version 1.0.1.8.
Kato
Hi Kato-san,
I've attempted to upload the grid txt file, and found that the memory map expects UART_ADDR=4.
If the GUI does not find UART_ADDR=4, it will attempt a TCI or OWU communication check. I can disable these one-wire interface checks if the UART_ADDR does not match as it appears to cause additional problems. In the meanwhile, because my device is UART_ADDR=0 (default), I have updated the following lines in the txt to prevent the one-wire interface check to load correctly:
Original: 1F (PULSE_P2),86
New: 1F (PULSE_P2),06
The point here is to ensure the grid txt file's PULSE_P2 register value which contains the UART_ADDR bits matches the UART_ADDR of the device before loading the grid txt file.
;GRID_USER_MEMSPACE 00 (USER_DATA1),00 01 (USER_DATA2),00 02 (USER_DATA3),00 03 (USER_DATA4),00 04 (USER_DATA5),00 05 (USER_DATA6),00 06 (USER_DATA7),00 07 (USER_DATA8),00 08 (USER_DATA9),00 09 (USER_DATA10),00 0A (USER_DATA11),00 0B (USER_DATA12),00 0C (USER_DATA13),00 0D (USER_DATA14),00 0E (USER_DATA15),00 0F (USER_DATA16),00 10 (USER_DATA17),00 11 (USER_DATA18),00 12 (USER_DATA19),00 13 (USER_DATA20),00 14 (TVGAIN0),88 15 (TVGAIN1),88 16 (TVGAIN2),88 17 (TVGAIN3),00 18 (TVGAIN4),00 19 (TVGAIN5),00 1A (TVGAIN6),01 1B (INIT_GAIN),C0 1C (FREQUENCY),64 1D (DEADTIME),80 1E (PULSE_P1),06 1F (PULSE_P2),06 20 (CURR_LIM_P1),15 21 (CURR_LIM_P2),D5 22 (REC_LENGTH),03 23 (FREQ_DIAG),00 24 (SAT_FDIAG_TH),EE 25 (FVOLT_DEC),7C 26 (DECPL_TEMP),0F 27 (DSP_SCALE),00 28 (TEMP_TRIM),00 29 (P1_GAIN_CTRL),24 2A (P2_GAIN_CTRL),00 2B (EE_CRC),94 40 (EE_CNTRL),00 41 (BPF_A2_MSB),56 42 (BPF_A2_LSB),72 43 (BPF_A3_MSB),F3 44 (BPF_A3_LSB),72 45 (BPF_B1_MSB),06 46 (BPF_B1_LSB),47 47 (LPF_A2_MSB),7C 48 (LPF_A2_LSB),D3 49 (LPF_B1_MSB),01 4A (LPF_B1_LSB),97 4B (TEST_MUX),00 4C (DEV_STAT0),80 4D (DEV_STAT1),00 5F (P1_THR_0),88 60 (P1_THR_1),88 61 (P1_THR_2),88 62 (P1_THR_3),88 63 (P1_THR_4),88 64 (P1_THR_5),88 65 (P1_THR_6),84 66 (P1_THR_7),21 67 (P1_THR_8),08 68 (P1_THR_9),42 69 (P1_THR_10),10 6A (P1_THR_11),80 6B (P1_THR_12),80 6C (P1_THR_13),80 6D (P1_THR_14),80 6E (P1_THR_15),00 6F (P2_THR_0),88 70 (P2_THR_1),88 71 (P2_THR_2),88 72 (P2_THR_3),88 73 (P2_THR_4),88 74 (P2_THR_5),88 75 (P2_THR_6),84 76 (P2_THR_7),21 77 (P2_THR_8),08 78 (P2_THR_9),42 79 (P2_THR_10),10 7A (P2_THR_11),80 7B (P2_THR_12),80 7C (P2_THR_13),80 7D (P2_THR_14),80 7E (P2_THR_15),00 7F (THR_CRC),28 EOF
Hi Akeem-san,
Thank you for your support.
I just confirmed that the difference between the old sample code and the new sample code is only on line 33, so I will try to check it using the latest GUI.
I greatly appreciate your cooperation.
Kato
