where can i find code examples for PGA305?
Just find that under the PGA305 datasheet section 7.3.16.1.2 EEPROM Programming Procedure, says as follow:
For programming the EEPROM, the EEPROM is organized in 16 pages of eight bytes each. Write to the 8-byte EEPROM cache to program the EEPROM memory cells. Select the EEPROM memory page to transfer the contents of the EEPROM cache.
What is this deal of programming and not programming? please be a bit more specific, what needs to be programmed? what is the procedure to set all the values to the registers that need to be set for proper device functioning? what is the procedure to store the device calibration in EEPROM?
