Dear Team,
My customer is using PCT2075 right now.
I will need your help here to clarify some question.
Right now PCT2075's temp default is around 80C, after start-up the customer will use I2C modify thermal shut down to 100C.
If the customer removes the plug during high temp, and replug in will cause PCT2075's temp thermal shut down go back to default value 80C which cause system can't turn on successfully.
Can TMP1075 also modify temp fault by I2C, how?
Can TMP1075 modify temp default value?
BR
Kevin
