Other Parts Discussed in Thread: AWR1642, AWR1243
Hi All,
After a lot of effort and re installation mmWave studio finally doesnt crash on my PC.
But now when I open it I get following error in output window.
I hope this time its possible to solve the problem and work one time with DCA1000 :)
Because I have changed my PC and bought new Ethernet card that was supposed to be the cause of error last time.
Mostafa
GM: Constructor
GM: Sat Jan 19 11:07:37 2019
RSTD.Transmit("/Settings")
[11:07:37]
[11:07:37] ### Running Startup script: "C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Scripts\Startup.lua" ###
[11:07:37] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[11:07:37] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[11:07:37] Scripter ignored: Attempt to UnBuild() again or before Build.
[11:07:37] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\Clients\\\\LabClient.dll")
[11:07:37] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[11:07:37] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[11:07:37] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[11:07:37] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[11:07:37] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[11:07:37] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_00_00_02\\mmWaveStudio\\RunTime\\SAL.dll")
[11:07:37] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[11:07:37] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[11:07:37] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[11:07:37] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[11:07:37] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[11:07:37] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[11:07:37] RSTD.Transmit("/")
[11:07:37] RSTD.SaveSettings(): Settings saved to "C:\Users\mostafak\AppData\Roaming\RSTD\config.xml"
[11:07:37] RSTD.Build()
[11:07:37] RSTD.AL_Build()
[11:07:37] RSTD.AL_LoadXml()
[11:07:37] RSTD.AL_Init()
[11:07:37] RSTD.Clients_Build()
[11:07:37] GM: Init
[11:07:37] GM: Loaded 'C:\ti\mmwave_studio_02_00_00_02\mmWaveStudio\Clients\\LabClient.dll'
[11:07:37] GM: 1 Guest (s) init
[11:07:37] GM: 1 Module(s) init
[11:07:37] GM: 2 Tab (s) init
[11:07:37] RSTD.Client_LoadXml()
[11:07:38] [RadarAPI]: Starting Matlab Engine..
[11:07:40] [RadarAPI]: Matlab Engine Started!
[11:07:44] [RadarAPI]: ar1.LoadSettings('C:\Users\mostafak\AppData\Roaming\RSTD\ar1gui.ini')
[11:07:44] [RadarAPI]: Error: Index was outside the bounds of the array.
[11:07:44] Trace:
[11:07:44] at AR1xController.ScriptOps.getMatlabPostProcVersion()
[11:07:44] TESTING = false
[11:07:44]
[11:07:44] ***Script completed successfully.***
