AWR1642: crystal oscillator selection
Part Number: AWR1642
I'm encountering a long lead time for the CX3225SA40000D0PTW-CC xtal oscillator that is recommended by TI. What are some tested alternatives you would suggest us to use?
At the same time, we found a supply of CX3225SA40000D0PTW-Z1 (instead of -CC that's used in TI's EVM), they have slightly worse frequency characteristics. The frequency stability is +/-50e-6 instead of +/-15e-6, frequency temperature characteristics is +/-200 e-6 instead of +/-150 e-6. Do you think the -Z1 parts are okay to use with the AWR1642 chips? I've attached the corresponding data sheets.
-jq
CX3225SA40000D0PTWZ1.pdf
CX3225SA40000D0PTWCC.pdf
  • Hello JQ,
    The crystal needs to meet the specifications listed in section 5.10.2.1 of the device datasheet. Proper crystal selection is very important for good RF performance, so I would not deviate from what is used on our reference designs unless absolutely necessary.
    Adrian
